Battery System Error on take-off
2079 27 2018-9-29
Stokesy_SWFC
Flight distance : 6368 ft
Hi all,
I haven't flown my bird for a good while so when I powered her up, I was requested to update firmware. Everthing seemed to go fine!
However, as soon as I take off, I immediately get a Battery System Error (red lights) and low voltage message.
I've rolled back the firmware and updated again but still the same.
I've tried both my batteries... Both the same so I'm guessing it's the drone itself?!?!!
Can't do anything.. Please help!!!
Thanks in advance,
Simon
2018-9-29
ALABAMA
Flight distance : 10442687 ft
Try refreshing the firmware again.
2018-9-29
Stokesy_SWFC
I've done this.
I downgraded the firmware and still the same.
I've now installed the latest again but still getting battery system error.
2018-9-29
Peterx
Flight distance : 1499708 ft
If you leaved the FW bin file on the SD card then power up your P3 system and observe the refresh of the battery FW via go app
2018-9-29
Stokesy_SWFC
The .bin file is on the ad card.
Do I just insert each battery and power on the remote and bird?
The strange thing is... When the bird is warming up or ready for flight all seems good. It's only when I take off that I see the errors????
2018-9-29
Stokesy_SWFC
Also, the .txt file says success at the end
2018-9-29
Stokesy_SWFC
I've just looked on the sd card... The bin file has the filename P3C_FW_V99.99.9999.bin Is this correct?!?!?!
Is this correct??
According to the DJI website, the latest version is P3C_FW_V01.09.0200.bin
Could this be the issue?
2018-9-29
Weiguoorng
China
We CTECHI Group is a leading lithium manganese dioxide battery, lithium iron disulfide battery,lithium sulfur dioxide battery and lithium iron phosphate battery manufacturer and exporter in China, we are not only focus on provide single cell but provide battery assembly and do OEM service for customers, CTECHI has captured 80 percent of overseas markets in the past 16 years with more than 2000 reliable customers in our customer management system, which has been being one of the leading enterprises with the most complete category in China's battery industry.
We also are battery solution provider, if you have any request, please don't hesitate to contact us. This is our web superlithiumbattery.com
2018-9-30
Peterx
Do you have a screen shot of you battery status ? The FW filename is right if you did the upgrade via Go app.
2018-9-30
Stokesy_SWFC
After auto take-off the drone hovers but as soon as I ascend I get the error message.
2018-9-30
Mark The Droner
Flight distance : 2917 ft
I would clean the battery contacts - see if that helps.
Large gold tabs in AC
Tips of data contacts in AC
Data contacts on battery
Isopropyl alcohol works nicely
2018-9-30
Stokesy_SWFC
If it was the contacts I would get the error on power up. The error only comes on when I start the ascend.
2018-9-30
Peterx
Are the 4 pins in AC by side the 2 power pins clean too? They are reading the battery status and conduct the data to the main board of the P3. Your battery cells are fine.
2018-9-30
Stokesy_SWFC
Peterx Posted at 2018-9-30 12:04
The pins look fine... I gave them a wipe and the battery contacts too... Still same!
2018-9-30
WD9EON
Flight distance : 686886 ft
Stokesy_SWFC Posted at 2018-9-30 12:56
Is it a DJI battery or a clone?
2018-9-30
Bashy
Flight distance : 2354357 ft
Perhaps the battery is EOL, the take off is putting too much strain on it? or, the battery is not getting the FW update
2018-9-30
Peterx
Did you have a look to the contacts in the aircraft too ? Are they straight ? If 1 pin bent only few degrees and you take off then the Ac loses the connection to the calculator unit inside the battery. If i read right before the take off it´s all ok and during take off the error message pops up.
2018-9-30
Stokesy_SWFC
Bashy Posted at 2018-9-30 20:03
How do i tell if the battery is updating correctly?
2018-10-1
Stokesy_SWFC
Peterx Posted at 2018-9-30 21:52
The pins look fine. I'll take another look later and post a photo when im home feom work.
This is so annoying now. Can't do a thing with it until a resolve this issue.
2018-10-1
Stokesy_SWFC
Stokesy_SWFC Posted at 2018-10-1 04:33
Both batteries have less than 20 charges.
2018-10-1
ALABAMA
This may sound stupid, but since this happened after an update, keep trying to update to the latest firmware over and over again.  It may just be a quirk, or you could have some damaged hardware.
2018-10-1
stuka75
Flight distance : 85682 ft
Sounds like battery has lost capacity. You charged it fully before attempting flight and got all four lights? If it sat on shelf for long period it may have gone into hibernation mode. the first picture doenst make sense without any low battery or critical battery warnings, but does have battery voltage??
2018-10-1
Peterx
The voltage seams to be ok for 65% charge on battery but the chip in and around the battery tells critical low voltage???
2018-10-1
Stokesy_SWFC
All looks good.
2018-10-1
Peterx
Nothing strange,looks ok. Try a refresh with the original file name P3C_FW_V01.09.0200.bin . Delete the other FW file  and the log file before you copy that to your SD card.
Power up the RC and AC (without card in cam) wait for the reaction of the AC and then insert the card. Wait a minute or two.
2018-10-1
Peterx
Got you any fix via software yet?
2018-10-2
Stokesy_SWFC
I did what you said.
Only firmware on sd card.
Powered up then inserted sd card.
Got same error.
2018-10-3
Stokesy_SWFC
When I powered up the AC without the SD card, I got a red flashing LED.
When I inserted the SD card, I got a solid green LED.
This log was added to the SD card:
========== 2014.01.01 00:00:16 remo-con disconnect======
Packet: P3C_FW_V01.00.0017.bin
Upgrading ...
========== 2014.01.01 00:00:15 remo-con disconnect======
Upgrading ...
Upgrading ...
========== 2015.10.01 17:35:49 =====================
Packet: P3C_FW_V99.99.9999.bin
Upgrading ...
Result: Success.
========== 2016.03.25 12:18:37 =====================
Upgrading ...
Result: Success.
========== 2017.05.11 13:00:35 =====================
Upgrading ...
Result: Success.
========== 2018.08.31 15:12:12 =====================
Upgrading ...
Result: Success.
========== 2018.09.27 18:58:49 =====================
Upgrading ...
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3C_FW_V01.08.0100.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2018.09.28 10:46:38 =====================
Upgrading ...
Result: Success.
========== 2018.10.03 13:48:28 =====================
Packet: P3C_FW_V01.09.0200.bin
Result: Abort.
Result: Abort.
========== 2018.10.03 14:27:55 =====================
Result: Abort.
2018-10-3
