Ronnie s shakes violently at 90 degrees
914 6 2018-9-29
Baaen1977
Flight distance : 3788520 ft
hi all
When I tilt my ronini s 90 degrees to the right the unit violently shakes to the extent the gimbal arms start hitting one another.
The unit is balanced, tuned and loaded with a gh5. It almost seems that the motors can’t handle the weight.
Concerned that the nit will break or damage the camera.
Anyone else experiencing this?
Cheers
2018-9-29
Hi Baaen1977, sorry to hear that, may I know if you are running the latest firmware? Please tilt the device 45°, then check if the Power value of all the motors is in the range of +/-5. If not, the device will need to balance again.
If the issue persists, any chance to share us a short video for further support? Thank you in advance.
2018-9-30
Baaen1977
Hi. Video is in link below. Also attached are screen shots of auto tune and motor parameters at 45 degrees as requested. Thanks
http://82.32.163.123:8080/share.cgi?ssid=0Atbdy1
2018-9-30
Baaen1977
also, yes, latest firmware v1.5.0.40 installed
2018-9-30
Baaen1977
DJI Mindy Posted at 2018-9-30 00:45
Hi. Were you able to review my ronin s issues?
Thanks
2018-10-2
Baaen1977 Posted at 2018-10-2 13:11
Thanks
Sorry for my late response because of the long holiday, may I know if you made Auto Tune after updating to the latest firmware?
2018-10-8
Baaen1977
yes, I autotuned after the firmware update
2019-1-8
