marktottymy
Flight distance : 91860 ft
I'm not sure what it indicates, but do you hear a soft click sound from the LG servo when you do the Travel Mode command ? I had the same problem as you, I could hear the click but no response from servo. Eventually I went into travel mode with the screw driver,but still had problem. Although there was no resistance I did add a touch of white lithium grease to the shaft in case it helped. Finally, I put it in Travel Mode and shut down, then restarted while connected to Assistant 2 and refreshed firmware and restored factory defaults. HERE IS THE STRANGE BIT OF DATA: If I remember correctly, this problem only occurred after I switched from using the Android GO APP to then IOS version of Go APP, and since i did the factory reset and went back to Android, I have not had any problem. The servo seems in good health so my guess is that either there is a glitch in the software that tells the LG servo to stop when by mis-reporting excess current caused by too much resistance, or there is a glitch that locks the LG because it is mis-reporting the presence of the gimbal. Good luck. |
