New Mavic Air Firmware Released(2018.09.30)
123Next >
19491 82 2018-9-29
DJI Support
Flight distance : 2408 ft
China
Overview
  • Date: 2018.09.30
  • Aircraft Firmware:  v01.00.0500
  • Remote Controller Firmware: v01.00.0200
  • DJI GO 4 App iOS: v4.3.0
  • DJI GO 4 App Android: v4.3.0
What’s New?
Aircraft:
  • Fixed the issue where the aircraft behaved abnormally when it misidentified a subject in ActiveTrack.
  • Fixed the issue during RTH where the aircraft continued to fly backward when it sensed obstacles both in front and behind.
  • Fixed the issue where the time displayed on photos was incorrect.
  • Fixed the issue where the aircraft flight distance was still restricted despite the Distance Limit being disabled in DJI GO 4.
  • Fixed the issue where the abnormal current warning appeared too frequently in some situations.
  • Fixed the issue where the aircraft could not land due to issues with the remote controller control sticks.
Remote Controller:
  • Added the ability to adjust the camera parameters. Press and hold the customizable button and toggle the gimbal dial to adjust (requires aircraft firmware v01.00.0500 or later).
Notes:
  • Make sure you update the DJI GO 4 app to the latest 4.3.0 version or higher before updating the firmware.
  • Restart the aircraft and remote controller after the update is complete.
  • Please note that the firmware update may reset various Main Controller Settings, such as the RTH Altitude and Maximum Flight Distance, to factory defaults. Before the update, take note of your preferred DJI GO 4 settings, and readjust them after the update to suit your preference.
  • This firmware update resets the camera settings.
  • If the firmware upgrade fails, restart aircraft, remote controller and DJI GO 4 or DJI Assistant 2, and retry.
2018-9-29
HereForTheBeer
Flight distance : 5014068 ft
woooooooo yay
fyi, staff, you need to pin this to the top...
2018-9-29
HedgeTrimmer
HereForTheBeer Posted at 2018-9-29 20:17
woooooooo yay
And DJI needs to update their Webpage for Mavic Air Download section!
2018-9-29
HereForTheBeer
HedgeTrimmer Posted at 2018-9-29 21:28
yea i know.. its almost their chinese holiday though so they probably rushing doing all this last minute stuff..
2018-9-29
HedgeTrimmer
HereForTheBeer Posted at 2018-9-29 22:05
I truly hope you are right.  That in a rush, somebody forgot to update Mavic Air Download section with latest release note (2018/09/30).
What I am afraid may have happened is somebody here did not get the message that things were on hold.
2018-9-29
HedgeTrimmer
With all the confusion...
Have you been able to download and update your Mavic Air to .0500 FW?
2018-9-29
HereForTheBeer
HedgeTrimmer Posted at 2018-9-29 22:18
yep, installed without much of an issue.. only issue i ran into was initially only update appeared was RC update...then both came in after a reboot.
2018-9-29
HedgeTrimmer
HereForTheBeer Posted at 2018-9-29 22:22
That is great news.
.0500 FW for Mavic Air can be downloaded and installed.   Even if it requires a reboot.
2018-9-29
Optimus_Prime
Flight distance : 489918 ft
Vietnam
Great one..updating
2018-9-29
woooooooo yay
Hi there, we have pinned this thread to the top and highlight. Thanks for reminding.
2018-9-29
Hi HedgeTrimmer, we have updated the release notes in the download section, thanks for reminding.
2018-9-29
Wachtberger
Flight distance : 261509 ft
Here we go, thank you very much DJI!
2018-9-30
Slapbladder
I had to use DJI Assistant as the DJI Go 4 app failed to update the quad but worked for the controller.
2018-9-30
Henrijs
Flight distance : 2760197 ft
Latvia
What is that? How it works?
2018-9-30
Wachtberger
Henrijs Posted at 2018-9-30 00:52
Just try it and watch the camera parameters in the upper right corner of DJI GO 4 ;-)
2018-9-30
Wachtberger
Update went very smooth for both aircraft and RC with mine. I had two flysafe database updates in addition.
2018-9-30
JJBspark
Flight distance : 1588317 ft
Oops, a question...
I have a device on 4.3.0 and another on 4.2.16.
How does my MA knows at updating wich GoApp version i have in use?
Or is this to convince people to use 4.3.0 ??
DJI says > "Make sure you update the DJI GO 4 app to the latest 4.3.0 version or higher before updating the firmware"
Uh, think i know the answer; you need 4.3.0 to update the RC. NAh, only when updating via your GoApp.
cheers
JJB
2018-9-30
nixuspix
Flight distance : 2771453 ft
Latvia
Anyone has tested it? Please share your opinions
2018-9-30
neilhamilton
FYI to anyone updating. I had to recalibrate my controller as there was an issue with the aircraft. When I tried to fly backwards in controller mode 2, the aircraft instead descended. This was intermittent but regular. It also became obvious when calibrating as a pull down on the right stick made both sticks indicate down. Recalibration solved the problem and all is well now.
Everything else seems perfect judging by my short test. It's a little windy here today to try properly. Certainly more stable whilst hovering though.
2018-9-30
Ridg
Flight distance : 232306 ft
once assigned, pressing and holding the custom button and then moving the gimbal dial will adjust the shutter speed
NB this is a jog action e.g. holding the dial left or right will no continue to cycle through shutter speeds.
2018-9-30
Ridg
nixuspix Posted at 2018-9-30 01:39
I've done the remains of the battery after the update.
Yaw after launch looks to have been fixed (main issue I had)
Video is patchy at distance >600m 5.8Ghz but acceptable
Camera settings on the dial is a real nice touch for those that shoot manual
2018-9-30
i_seb
Flight distance : 230171 ft
Yes! I'm super happy about it. I will update my Air tonight!
2018-9-30
AIRQUAD
Flight distance : 12767953 ft
Sweden
Updated and everything worked just fine in my flights today
2018-9-30
Nanolab
Flight distance : 122165 ft
Updated this morning via DJI Go 4.3 on an Xiaomi MI8 without problem, and burned 4 full batteries for one hour just fine.
I didn't get the bird too far but everything was good !
Edit : Updating from .400 to .500 didn't reset the FCC trick
2018-9-30
小仙女的星巴克
Flight distance : 2202083 ft
Updated the Firmware 0500 using my laptop DJI Assistant 2 without issue. Then update the RC to 0200 on my Mate 10 Pro without problem. Flew 2 batteries using Go4 and 1 battery on Litchi ...great. The Go4 App reset my Height limit and RTH Height too so beware.
2018-9-30
JJBspark
Update here as well, only had to update my RC via the App ; dji assistent did not 'saw' the RC (MA yes)
Had a flight with my MA and Spark ; no errors! Only with the second MA battery a uncontrolled YAW move to the left just after take-off (the old "problem")
cheers
JJB
2018-9-30
EdisonW1979
Flight distance : 1366555 ft
JJBspark Posted at 2018-9-30 09:03
OK, this is bothersome, as the yaw glitch was one of the main issues widely reported by pilots here, so if DJI spent all these months to release a FW update they didn’t bother to correct some of the most reported issues, that really upsets me...
2018-9-30
JJBspark
EdisonW1979 Posted at 2018-9-30 11:33
Yep, in the log the compass heading reading is quickly plus 7 degrees, so the drone corrects this by turning to the left. Did notice this in the .400 fw, only after take-off that is. so it does look the same. i will add some data and recording tomorrow.cheers
JJB
2018-9-30
Vlas
Flight distance : 900633 ft
Japan
Thanks for the fixes
2018-9-30
EdisonW1979
JJBspark Posted at 2018-9-30 11:53
JJB
There's been no breaks in the rain here so I still can't do a test flight with 0500, but question...
After installing 0500, did you perform a compass recalibration and/or factory reset?
2018-9-30
JJBspark
EdisonW1979 Posted at 2018-9-30 15:59
Hi Edison,
Just did the update and restart of MA and RC.
Compass showed very green in the app so no calibration done.
Made a video of 2 .400 yaw glichtes and this one with .500 FW. I must say its still there but not as harsh as before.
See the yaw values in the chart.
cheers
JJB
2018-9-30
Ranini
Flight distance : 478422 ft
Mauritius
This is awesome, thank you dji, specially for the new camera adjustment feature .. dji so lovely .. thanks a lot for everything.
2018-10-1
Ulysses Paiva
Flight distance : 573310 ft
Flew 1 battery yesterday. Today I rechecked all parameters, recalibrated the sticks and flew another battery. I didnt get the yaw issue (yet) but on both occasions I noticed the AC sometimes drifting to the right. I dont know if it was due to the wind but I remember it used to fly straighter on previous FW.
2018-10-1
crazyray
Good luck everyone...........
2018-10-1
Rawsome
Flight distance : 230827 ft
Just aircraft and controller update, no batteries right?
2018-10-1
samgawthorpdji
Figure this will make little change to the issues I have been receiving on nearly every flight so may as well give it a go and see what happens....
Will do it by DJI Assitant, where can I download this from, can not seem to find it on the DJI site?? EDIT - found it
2018-10-1
hallmark007
Flight distance : 4805338 ft
samgawthorpdji Posted at 2018-10-1 08:59
Start up your craft and you will be prompted.
2018-10-1
hallmark007
Rawsome Posted at 2018-10-1 08:26
No batteries.
2018-10-1
fans206e8cc5
Hi first timer here looking for help! After updating the remote controller firmware the aircraft status on dji go 4 became main controller data error and error on IMU has shown but there is no response when I press the calibrate button. Tried to connect the RC to dji assistant but the USB doesnt work but it worked for the mavic air, any help in this is appreicated.
2018-10-1
Rawsome
Thank you kindly!
2018-10-1
123Next >
