hallmark007
Flight distance : 9827923 ft
So I have just updated to .500, I didn’t use assistant nor did I need to use assistant, in all my time updating FW only once was I forced to use assistant, always managed with no problems to update through dji go4 app, and this was the same with .500 .
I tested today, so at first when I launched I noticed video feed slightly glitchy, and kept getting strong interference warning, so switched off Bluetooth in airplane mode and the same problem , flew for about 50% battery, decided to come in and land to check everything was ok, and when landing I noticed I had forgot to lower one of the legs, so just hand caught, dropped leg and took off again, video latency was perfect warnings gone, so just be careful to check legs are down when flying.
So I tried distance, no issues, sport mode no issues, tripod, active track, tap fly all modes , POI and all quick shot modes and had no issues, I tried hovering at approx 40 metres height in 15mph winds and Mavic Air remained very stable, both locked in sport and P mode. RTH with no issues, all sensors OA all working as they should, APAS although I have used this very little I thought I noticed that it was now a bit more responsive where before it may just stop, nw it seemed to make a bigger effort to move around the object.
New option to change SS works as it should and similar to Mavic Pro . Photos and video no change, Certainly for me .500 is working well as per test . There were some problems with .300 as we can read on the forum and some of these continued with .400 and some more like motor current warning, I didn’t have any of these problems with exception of motor current, so fo me FW .500 is an improvement on all other FW’s for Mavic Air. |
