blaxthos
Skypuppy Posted at 2018-10-14 17:11
Since the firmware update, I have experienced a rather puzzling occurrence- once in the air, my Mavic Air will slowly and of its own volition turn to the right. The position is otherwise static, it simply rotates right. I can swivel it back to where it was pointed and then watch as it rotates right. This has never before happened so I have no choice than suspect the update. More aggravating is that the action is not consistent, that is, that it didn’t occur all the time but you can’t predict when it will do so but it always to the right. Anyone else have a new problem?
Same problem here, occasional rotation when hovering since the update. Rotating counterclockwise works, but immediately starts rotating clockwise again when I let go of the stick. No other issues so far; I've flown in pretty serious sustained wind and gusts without issue (other than the occasional rotational drift). |
