Zebra stripes on my camera feed
6522 8 2018-9-30
georgieB
Flight distance : 33212 ft
Philippines
Hi,
I had this problem before the .500 and rc firmware update and also did appear after the firmware upgrades.  I was flying this morning and noticed that the video feed had the zebra stripes when an obstacle like a white sheet is detected or a white water tank.  when I checked the video cache (since my regular video didn't show up on the sd card - posted a thread on that earlier), it was fine on the phone and no stripes.
This evening after both the firmware and fly database upgrade, powered both air and rc and note 4.  I was indoors with not that much lighting and the stripes started to appear.
Please advise and thank you.
2018-9-30
neilhamilton
This sounds like an exposure indication. That is pretty common on most video products these days and can easily be turned off in the camera settings.
2018-9-30
msinger
Flight distance : 228255 ft
You can disable that setting in the following section of DJI GO:
2018-9-30
Henrijs
Flight distance : 4517064 ft
Mexico
OMG, there is zebra hiding in your room
2018-9-30
georgieB
Philippines
Thank you all for the help
2018-9-30
DJI Wanda
Hi. Thank you for reaching DJI Forum. You may refer to the post #2 and #3 and please let us know if it helps.
2018-9-30
OneDoesNotSimply
Flight distance : 662644 ft
You should read the manual for DJI Go. I learned quite a bit from it:
https://store.dji.com/guides/dji-go-4-manual/
There are some setting smentioned that might not apply to the Mavic Air as DJI Go is used for a lot of different models.
Oh, and you might want to be careful posting screenshots with your GPS location on them when you're at home ;)
2018-9-30
Amjad1983
Flight distance : 310489 ft
United Arab Emirates
Henrijs Posted at 2018-9-30 05:49
2018-9-30
Suren
Flight distance : 13438648 ft
South Africa
Those are over exposure lines, turn them off in camer settings
2018-9-30
