DJI Gamora
Hi russhog. We do apologize for the troubles you had recently. Have you updated the firmware of your aircraft to its latest version? I'd like to ask if you are getting issues with image transmissions after the aircraft flies away from a short distance? If so, try to fly the aircraft in an open area free of interference. The interference can come from, including but not limited to, Wi-Fi hotspots, routers, Bluetooth devices, wires, substations, base stations, and broadcast towers. During use, do not cover the mobile device’s antenna. For iOS devices, the antenna is mounted on the upper left corner of the phone. It is recommended to hold the mobile device horizontally and place the Home button of the mobile device on the left side. For Android devices, the antennas are on the four corners of the mobile device. You can check it based on the mobile device model. Do not fly vertically upwards. It is recommended that the flight distance be larger than the flight height. Let us know what happens. We're here to help you. Thank you.
