Matthew Dobrski
Flight distance : 1831050 ft
Burlingtonfilms Posted at 2018-9-30 14:43
Thank you both for your replies.
I loosened the arm clamp but it looks like the grooves are worn down a bit. It is aligned now, but I'll need to order a new plastic clamp piece.
I doubt if ordering this clamp alone is possible. Most likely DJI will refuse to supply you, suggesting sending for service instead. It'll not do you any good anyway, since the replacement will require disassembly of the entire boom. Definitely achievable, but ... |
