Left stick of my remote controller out of order?
3230 10 2018-9-30
MA3525
During the last flights with my Mavic Air, using the remote controller in Mode 2, when I ask to go down with the left stick, the drone starts to turn on itself.
When trying to calibrate the remote controller, pointing the stick down, here is the result.
Is the left stick of my remote controller out of order?
Mavic Air 01.00.0500
Remote Controller 01.00.0200
Remote controller
2018-9-30
Amjad1983
Flight distance : 310489 ft
United Arab Emirates
just try to reset to factory  and download new firmware
2018-9-30
MA3525
Oh no... Error message !
Reset
Reset
2018-9-30
Ovi 1
Flight distance : 351545 ft
I have the same issue
2018-9-30
MA3525
The same 2 malfunctions: left stick AND error message to restore the factory settings?
And what did you do?
2018-9-30
Ovi 1
I think I have a defective remote . I hope I can send it back and get a replacement.
2018-9-30
knas
Norway
I have the same problem. pulling stick down give output 100%down and around 70% to right. putting stick up give 100% up and around 50% to left. have tried calibrate but didnt work. And i alsow get error when trying to do a factory reset. Have you any solution for your problem yet?
2018-10-5
Qi Yuan
Malaysia
knas Posted at 2018-10-5 13:09
me too dang it
2018-10-22
MA3525
Finally, my remote controller was sent to the DJI after-sales service
2018-10-22
Ben Mason
Flight distance : 610614 ft
This is usually a hardware fault, however you can try.
1. Make sure you are using a compatible device(phone/tablet)
2. Calibrate the controller in the app(while disconnected from the drone)
3. Refresh the firmware.
4. Flick the stick to a max position and release, this is a long shot but i have fixed a stuck stick this way.
Again you can try these but it is most likely a hardware fault with the stick.
2018-10-22
MA3525
I just received the new RC and after charging the battery at 100%, I turn it on : continuous beeps !!!
Update RC 01.00.0200 via DJI Assistant 1.2.4 + pairing with the Mavic Air + calibration, with the sticks in the central position, the left stick indicates 0% downwards and 12% upwards !!
And always msg Error restart factory
Why always this stick left ?
In this thread : https://forum.dji.com/thread-132640-1-1.html,
DJI Thor specifies :
Basically, there will be some chances that RC makes a sound: 1. Low battery; 2. RC sticks are not in the central position; 3. Firmware upgrade failed; 4. Leave the RC in idle itself after powering on.
Visibly, my RC is in case # 2. New repair ?
2018-10-24
