HereForTheBeer
Flight distance : 5381368 ft
hallmark007 Posted at 2018-10-1 13:37
The logs would show the area you are flying in and if there is a problem with RTH , RTH should not be a problem if it is not working properly you shouldn’t be flying your aircraft, logs can show and help in many things, I see you have already opened up your RC which effectively renders your warranty useless .
actually surprisingly the RC appears to use nothing that's tamper evident.. at least in my case, not even the screws had anything tamper evident and no seals broken.. all that being said though, if my RC failed me complete one day, i'd buy a replacement unit on ebay or something instead of trying to ever make another claim with DJi again... my experience with Dji's customer service has been far from ideal, the battery issue i had... took 3 levels of customer service and multiple cases including one against their own customer care for them to accept my claim and taken approx a month, i rather spend $100 and avoid them, if im honest.
i agree, i shouldn't be flying if the RTH is having issues... no one should if they having issues since the update that may endanger the aircraft. i think this update was not meant for release yet and the chinese holiday maybe has put dji on a bit of a rush, so hopefully, when they come back into their offices they can push out .501 or something pretty quickly and fix loose ends up. |
