Hi Raiderfan, may I know which unit do you use? The message might appear if there is interference in the environment, you may change to another open field without interference to verify.
DJI Susan Posted at 2018-9-30 17:57
I use an iPhone 7 plus this message always appears at all location. I have tried several open fields with the same results.
Raiderfan Posted at 2018-9-30 19:23
Sorry for the confusion. The unit we mentioned here is the DJI product, that is to say, which drone do you use? Have you enabled the airplane mode and disable the Bluetooth to check?
DJI Susan Posted at 2018-9-30 22:23
Sorry I have the Mavic 2 zoom........I have enabled airplane mode and disabled the bluetooth, this did not help.
Raiderfan Posted at 2018-10-1 08:31
Hi Raiderfan, may I have a screenshot of your Image Transmission Settings page? It is recommended to set the channel to Dual and the Channel Mode to Auto to see if the issue persists, thank you.
