DJI Tony
strixaluco Posted at 2018-10-8 16:08
Hi Tony, I reinstalled the DJI Go app on the Nexus 7 2013, flew the P3P 2 days ago and the safety pop-up window appeared just once, I checked it and it disappeared. So this problem has been solved. However I noticed there was a black screen in the bottom left corner, so I could not see where the drone was heading when far from me as there was no arrow. This is new, before reinstalling the app I never had this problem.
Then I flew the P3P with Iphone SE latest IOS and I had no problem whatsoever, all working well, therefore I think it is just a problem of the Nexus 7 2013 running on Android. It's a pity because so far it did a great job and I only use it to fly the drone.
Hi, Thank you for your updates. Glad that somehow it sorted the initial issue. Based on our compatible devices, the Nexus 6P is only compatible with our DJI GO app. You can check the image below for your reference on the compatible devices. Thank you for understanding the situation.
