Fly more battery charging....
5831 10 2018-10-3
Jeetley
Flight distance : 123944 ft
hi folks...after taking the plunge and purchasing a M2 Zoom etc withe the fly more  combo i notice that if i put all 3 batteries on the charging hub they only charge up one at a time..not simultaniously.
at first i was concerned but went through youtube after tutorial videos and found out this is normal.
my question is does it seem posssible or is it expected that there might be a firmware update  so as they can all charge together ??
this one at a time thing makes no sense to me
thanks
Brian
2018-10-3
msinger
Flight distance : 228255 ft
While it's possible DJI could release a firmware update for the charging hub, it's not likely the hub will ever charge more than one battery at a time. It's just not something DJI normally does.
2018-10-3
Hedsic
Flight distance : 478757 ft
Non of the DJI hubs charges multiples together. You will need to purchase an aftermarket charging station for that.
2018-10-3
jwt-873
Flight distance : 6754350 ft
The supplied charger provides 17.6Volts at 4.41 Amps.  That's 60 Watts.   Three batteries could take up to 180 Watts.    I don't think it has the capacity to charge three at once.  (Mine gets pretty hot just charging the one battery that came with my Mavic 2)
2018-10-3
Pequodd
By design it charges batteries individually in order of highest to lowest charge level, Let's you get back in the air asap.
I don't see much merit in charging all the batteries at a reduced charge rate (given we're using the same 60W charger, or 80W for the car charger).
Unless we're talking about longevity of batteries by charging at a lower C.
2018-10-3
Blellow
Flight distance : 1311056 ft
The spark's hub charged simultaneously, so it was a step back for the mavic not to.  That's the way it goes.
2018-10-3
davidmartingraf
Flight distance : 106566408 ft
That would be a useful feature on the Mavic 2, especially since the Spark has balance charging and it really makes things more efficient and quick to get back on and shoot some video.
2018-10-3
DJI Natalia
Hi, I appreciate your time bringing this topic to us. Regarding your concern, We will forward this to our R&D department for clarification and future request. If you have further question, please let us know. Thanks for your understanding.
2018-10-3
Jeetley
Hedsic Posted at 2018-10-3 13:09
this is whats confusing as the sparks charging hub does all three at once
2018-10-4
Manta
Flight distance : 1738937 ft
New Zealand
You'd need a power supply four times as powerful as the one supplied in order to charge 4 batteries in parallel; no amount of firmware update is going to make that happen!
2018-10-4
Lucas775
Flight distance : 50642090 ft
The wall charger I received with my fly more kit won't work with my hub charger I get a red light on the hub as soon as I power it up.  So I can only charge one battery at a time for the moment until DJI stock the wall chargers again.
2018-10-4
