Is the ntsc and pal setting removed
7793 12 2018-10-3
kivo123
Sweden
Is the ntsc and pal setting removed?
I cant find it anywhere in the latest version of the app
2018-10-3
DJI Tony
Hi, Thanks for your inquiry. I would like to ask if the DJI GO 4 app is under video or photo mode? Could you please provide a screenshot of this concern? May I know if this option is not available for Mavic 2 Pro and Mavic Pro? Kindly keep us posted for further help. Thank you for the support.
2018-10-3
kivo123
Sweden
DJI Tony Posted at 2018-10-3 16:21
Hello,
Its not listed under the photo/video settings. I am using the latest version from app store in sweden.
2018-10-4
DJI Tony
kivo123 Posted at 2018-10-4 10:44
Hello,
Hi, Thanks for your prompt reply. I noticed that you have 2 drones, did this option is not available for both of your drones? Please keep us posted. Thank you for the support.
2018-10-5
kivo123
Sweden
DJI Tony Posted at 2018-10-5 09:45
Hi Tony,
I sold my old Mavic but I can remember seeing that option in the setting when using the Mavic one. Could you kindly show me a screen shot where I can set the pal/ntsc setting in the app when using a mavic 2 pro please
2018-10-5
DJI Tony
kivo123 Posted at 2018-10-5 11:13
Hi Tony,
Sorry for the late response. May I know what mobile device are you using and the current version of your app? Please keep us posted on the latest information. Thank you for the support.
2018-10-7
kivo123
Sweden
DJI Tony Posted at 2018-10-7 09:16
dji go 4 v4.3.3
ios v12
here are some screenshots, cant find the setting for pal/ntsc
2018-10-7
DJI Tony
kivo123 Posted at 2018-10-7 14:01
dji go 4 v4.3.3
ios v12
Hi, Thanks for providing the screenshot. I was able to confirm your query, unfortunately, NTSC and PAL are no longer available with the latest DJI Go 4 app. Please let us know your further concern. Thank you for the support.
2018-10-8
Holx
Flight distance : 139331 ft
You don´t need the ntsc/pal switch actually.
Resolution for HD and UHD is the same in both systems. The only difference is the frame rate. 30 for NTSC and 25 for PAL. 24 exists in both worlds as "cinema" frame rate
Just choose the right frame rate when you select your recording resolution. Done.
Actually its better without the ntsc/pal switch because you can access all frame rates directly.
2018-10-8
DJI Tony
Holx Posted at 2018-10-8 09:37
Hi, Thanks for the additional information. Yes Kivo, NTSC and PAL would depend on your frame rates and resolution. Thank you for the support.
2018-10-8
The_Death_Angel
Flight distance : 134062 ft
So what do I do if my client wants me to shoot in 50 frames. The current app only allows 24, 30, 60, 120.
2018-11-20
Alicam
Flight distance : 10495866 ft
Hi i read all post , but my question is the 24fps in UHD is not real but 23.98 . How setting resolution i have an 24fps real ?
2019-10-1
Alicam
2019-10-1
