Manually Unfolding Props on Mavic 2?
1218 9 2018-10-4
Hedsic
Flight distance : 478757 ft
I've had this mentioned to me a few times so thought I would ask here. When starting the Mavic 2, should you manually open up the props when they are folded in before starting the motors? On my Mavic Pro I just start it up and let them unfold on their own as it starts to spin. I was told with the Mavic 2 the props are larger and weighed more so letting the motor spin with them folded and having the force open them will damage the motors and adds unneeded wear to them.
Is there any truth to this or no?
2018-10-4
msinger
Flight distance : 183694 ft
The Mavic 2 manual recommends unfolding the props before powering on the Mavic. If you want to avoid unneeded wear and tear, it would be a good addition to your pre-flight checklist.
2018-10-4
Blellow
Flight distance : 72848 ft
I open them for the same readon.  It just makes sense.
2018-10-4
Aardvark
Flight distance : 384432 ft
And you should really unfold props on Mavic Pro as well, page seven of manual indicates that it may affect the self diagnostics on start up if not unfolded.
2018-10-4
Hedsic
Good to know. Thank you for this information!
2018-10-4
DJI Paladin
Super Moderator
Flight distance : 318 ft
I agree on post #2, you should unfold the propellers of the Mavic 2 before the flight. You can also refer on the attachment below for our pre flight check list.
2018-10-4
davidmartingraf
Flight distance : 31303589 ft
I don't unfold them with my Mavic Pro because if you leave them to the centripetal force and you notice something wonky then it serves as another checkpoint of your drone to make sure it can go up successfully.
2018-10-4
GhostWolf010
Flight distance : 1118323 ft
On my pro I always unfold them myself, just to be sure they are unfolded and still in one piece.
2018-10-4
HedgeTrimmer
GhostWolf010 Posted at 2018-10-4 08:57
Unfolding - part of pre-flight check of props.
2018-10-4
rwynant V1
Flight distance : 2391175 ft
I would think there can be an initial SHAKE due to unbalanced rotating mass......which can and would cause eventual motor/airframe wear that is not desirable.
Randy
2018-10-4
