Paul_24M
Flight distance : 848369 ft
Poland
DJI Mindy Posted at 2018-10-8 19:02
Paul, sorry for my late response because of the Chinese National Day, the issue has been forwarded to our engineers for further analysis, I will keep you updated once I hear anything from them, please wait patiently, thank you.
Hello Mindy.
I`ve made some tests and i`ve got weird results. The issue is happening when offloading dng files to the harddrive. But the dng files on the Cinessd drive are correct. If i change the damaged frame with the original one it is repaired.
I decided to buy another cinessd and another ssd reader, as i thought that the problem is caused by those. But not, the problem is the same with new ones.
I am really distressed as i cannot be sure of anything if i wouldn`t do two backup at least.
And i have no idea what is going on. If the problem is caused when offloading it should point that the drone is ok. But at the moment i am not sure that. I am not sure of anything.
Regarding computer i have checked the offloading on workstation and also on laptop. The problems are the same. Is it possible that the problem is coming from usb port, i mean powering the reader from it? |
