Any solution to latest Mavic air firmware gimbals reset in the air?
935 6 2018-10-5
JerryS
Flight distance : 222897 ft
Maldives
Any solution?
2018-10-5
DJI Paladin
Flight distance : 318 ft
Our apologies for the inconvenience. Did you receive an error message? If yes, kindly provide a screenshot. You can restore the setting to factory defaults and refresh the firmware using DJI Assistant 2. You can download the software here: https://www.dji.com/mavic-air/info#downloads and follow the video tutorial below. If it is convenient for you, kindly provide a short video showing the issue so that I can check it on my end. You can use google-drive or Dropbox and provide the link here.
2018-10-6
JerryS
Maldives
DJI Paladin Posted at 2018-10-6 03:12
Our apologies for the inconvenience. Did you receive an error message? If yes, kindly provide a screenshot. You can restore the setting to factory defaults and refresh the firmware using DJI Assistant 2. You can download the software here: https://www.dji.com/mavic-air/info#downloads and follow the video tutorial below. If it is convenient for you, kindly provide a shot video showing the issue so that I can check it on my end. You can use google-drive or Dropbox and provide the link here.
https://www.youtube.com/watch?v=XPmWvxeSp7E
i didn't update yet. but all my friends are telling not to update. coz, they are in trouble of errors
2018-10-6
DJI Paladin
JerryS Posted at 2018-10-6 20:18
I understand. May I know if the drone experience crash before? Have you calibrated the gimbal already? Please provide a short video of the issue so that I can check it on my end. Thanks for your support.
2018-10-9
DJI Paladin
2018-10-9
JerryS
Maldives
my drone does not crash yet
2018-10-9
JerryS
Maldives
actually my MA, with .400 it has no problem. i can travel a distance of 3KM easily. and achieve 450M height without a problem. so im afraid to update
2018-10-9
