Where FCC/EC settings stored in: aircraft or rc?
1989 9 2018-10-6
Sain
Flight distance : 2838 ft
Ukraine
Hi to everyone. I'm new to dji (flying from 2013 year only on 250mm racing drones). I already purchaced spark and controller on eBay. Connected it together and saw "inconsistent firmware found" message. So I need to upgrade RC or downgrade Spark. In DJI go I see 11 channels (so its working in FCC mode). Where this info stored: in spark or remote? If I will upgrade RC it will be switched to EC mode? Or if I will downgrade aircraft this info will be deleted and it will be switched to EC?
2018-10-6
DJI Gamora
Hi Sain. Thank you for reaching DJI Forum. We do appreciate bringing this query to us. Kindly update the firmware of your DJI spark to its latest version. This will be stored in your aircraft. If you upgrade the remote controller it will be on CE mode. Thank you.
2018-10-6
Sain
Ukraine
DJI Gamora Posted at 2018-10-6 03:29
If this settings saved in aircraft, then it will be loosed when aircraft is upgraded or downgraded and not will be changed in case or upgrading remote controller. Or I'm not right?
2018-10-6
DJI Gamora
Sain Posted at 2018-10-6 03:40
Hi Sain, the settings will stay with the aircraft and the remote controller. The only thing that it will change is when you restore factory settings. Thank you.
2018-10-6
S-e-ven
Flight distance : 5922034 ft
Thailand
Don't worry, get yourself the updates, google DJI moded 2.0, start the bird connected to that one, all back to FCC, fly it with actual DJi Go4, cancel "switch to local settings"
2018-10-6
S-e-ven
Thailand
Question:
Isn't aircraft Firmware: V 01.00.1000 the latest?
Did I miss one?
2018-10-6
Wolferl
Flight distance : 23793 ft
Austria
S-e-ven Posted at 2018-10-6 04:20
Question:
Hi Seven,
That bothered me too. 1000 is the latest, at least my Spark does not show that I should do an upgrade. Weird.
Wolferl
2018-10-6
S-e-ven
Thailand
After another glimpse at the picture:
The updated version numbers show "update available", but the RC, with a lover version, isn't
Probably a glitch in the Go4, in combination with the older RC Version number?
2018-10-6
Sain
Ukraine
S-e-ven Posted at 2018-10-6 08:49
I think its a bug in DJI GO 4.
2018-10-7
Sain
Ukraine
Updated my spark fly more combo to latest version. RC was not bricked. FCC mode saved and not switched automatically to EC. Made 4 test flight. 1 time spark fall down after start from hand, but may be its my mistake. So seems everything work fine...
2018-10-7
