IOSD MarkII on screen display... Anyone else having this problem?
1847 5 2014-11-6
anthony.kolenbe
Suriname
Hi everyone,
I was wondering if anyone else has this problem. I have the IOSD markII connected with the A2 flight controller and the zenmuse z15-gh4. when I first hooked it up the display parameters (like flight mode, batt usage, altitude etc) where bright and clear on the display as can be seen in the second picture. Right after the first flight all the parameters suddenly scrambled across the screen and can barely be seen and used. This can be seen in the first picture (my display with current situation ).
Does anybody have this problem? How can I get the parameters clear and bright again?
Thank you
A. Kolenberg
2014-11-6
DJI-Sophie
China
Hi Anthony, please try: 1) update the firmware; 2) change another channel, 3) check whether there is any cable which could affect the screen dispaly.
2014-11-6
lennyschway
Flight distance : 1708412 ft
Your Mark II is bad.. I had the same problem on mine. It was brand new and only worked One time before the Down Arrow became scrambled. I tried re doing the firmware update and  trying different channels but the problem didn't go away. It is something internally wrong with the unit. I had the dealer replace it.
2014-11-6
anthony.kolenbe
Suriname
lennyschway@gma Posted at 2014-11-7 00:10
Your Mark II is bad.. I had the same problem on mine. It was brand new and only worked One time befo ...
Hey guys ive replaced the iosd and my on screen data is all good again. Thanks for the advise
2014-11-23
anthony.kolenbe
Suriname
2014-11-23
Blade_Strike
Super Moderator
Flight distance : 872694 ft
Thank you for the update.
2014-11-23
