Manual is not Manual!!! EV keep chancing in MANUAL
12Next >
7010 61 2018-10-7
DRAGenDROP
Flight distance : 25483504 ft
The Setting Manual is not Manual, the light keeps chancing in Manual.
I ask it here again, no answers in the other tread!
DJI?
2018-10-7
gnirtS
Flight distance : 5712575 ft
Thats what manual is.  Just like every other camera with manual control the EV is showing you how over/underexposed the current image is going to be with the settings you're using.
2018-10-7
KlooGee
Flight distance : 15944757 ft
In automatic mode, you change the EV and then it will automatically adjust the ISO and shutter speed to try to meet that exposure value you’ve set.  In manual mode, it is the opposite!  You set the ISO and shutter speed manually yourself and it shows you how well exposed it is via the “EV”.  Although when in manual mode, its actually not EV, but instead M.M.   I think this stands for meter mode, but don’t recall for sure.
2018-10-7
DRAGenDROP
Ok, I put it in a other way:
When i am in manual mode ( always), the light keeps chanching when I look around at light or dark.You see it goning up and down in the screen.
2018-10-7
saviour
Flight distance : 604203 ft
DRAGenDROP Posted at 2018-10-7 23:30
With light do you mean the EV?
That's obviously how it is when you look around and the brightness changes.
Let's put an example: You look at trees on the bottom. You adjust Shutter Speed and ISO to have an EV of 0 in manual mode. When you now look up into the sun, the Shutter Speed and ISO are set too bright. That's why the EV goes up. It is not an actual setting that makes the image brighter, it's just an INFO. The settings (Shutter Speed and ISO!) keep the same. The EV will be way above 0 though, because you look into a much brighter space.
2018-10-7
dancopter
Flight distance : 17901030 ft
United Arab Emirates
Is auto-iso enabled?
2018-10-8
Jos A
Flight distance : 11588 ft
you can lock AE, I do that just before taking a sphere. I program the C2 button for that
2018-10-8
gnirtS
Thats what manual exposure does.  YOU have to balance the exposure not the software.
2018-10-8
DRAGenDROP
no when I do Manual I meen Manual notting is auto.
The M in the app.
2018-10-8
DRAGenDROP
gnirtS Posted at 2018-10-8 02:33
When I am in M- Manual, I set the light my self , I set the iso the shutter and the Apature(F).
That way I control everything and when it is set it have to stay that way.
The problem is, that something is still moving and changing when I look at light out dark areas.
I never use Iso shutter or apature priority i always set M so that everyting is fix, the problem is that someting is stil moving or how ever you call it.
I fly 3 Inspire2, i know what Manual is, and works perfect on the Inspire's, bud does not with the Mavic 2 pro.
2018-10-8
DRAGenDROP
Again, ( I think my English is the problem).
I always work in Manual ( the M is where you set everyting manual ), I set it on M ( manual)
That way I fix the iso Manual, I fix the shutter manual, I fix the aperture Manual The problem with the Mavic (I have) is it still keeps chancing something in the light, and I do not know what, i see it's still doing someting with the lighting, going up and down( depents on where i look)
I did 3000 flight and I  know what I talk about.
2018-10-8
Charissa
Flight distance : 689334 ft
South Africa
DRAGenDROP Posted at 2018-10-8 02:47
I get what you are saying. The EV should not change automatically, because that defy the purpose of setting the ISO, and SS manually.
On any DSLR (proper ones), the EV can be set manually. It does not change when the ISO and SS gets set in Manual mode. Only in Auto mode, it will vary.
What is happening with the Air, is that they say, OK, you want ISO 100, but you actually need 200, so we will automatically (overexpose) change the EV to get more light.
So yes, this is not a TRUE manual setting. It is a semi automatic setting. (would also like to have it changed.) Using EV will also degrade Image Quality, same as upping the ISO. Would have liked to choose myself, what settings I wanted.
2018-10-8
Charissa
South Africa
Jos A Posted at 2018-10-8 00:40
Is that on the MA? Can I lock that AE permanently, or just before shots etc?
2018-10-8
eyecapture
Flight distance : 517848 ft
Clearly you don't understand what EV is. It's not a setting that can be fixed! It simply tells you the difference between what your manual setting is and what it thinks the automatic exposure should be. Only when your in one of the auto modes does EV "shift" the exposure for you.
2018-10-8
gnirtS
The lighting is going to change as you look around.  Because the exposure is locked.  If you have it exposed for a certain light then pan or move the light levels will change so the screen light levels will change and the EV will change to show its best guess at how over or under exposed it is.
In manual, nothing changes exposure wise so different light levels will be obvious.
2018-10-8
DRAGenDROP
ok
Let it be.
I set everything Manual, and still the camera does something with the settings/light ( i see it happen on the cristalsky) bud you don't see it changing in the numbers (app)
I send it back
2018-10-8
Jos A
Charissa Posted at 2018-10-8 05:20
MAVIC PRO ,
2018-10-9
fanscb6385d2
Flight distance : 281283 ft
You need to find the switch on the sun and stet it to "constant". With that done, the light on the scene you are filming will stay constantly the same and the ev values will not change anymore.
2018-10-10
gnirtS
fanscb6385d2 Posted at 2018-10-10 04:43
He'll need to turn off the "clouds" overlay too.
2018-10-10
DRAGenDROP
talking stupid I can do my self
2018-10-11
Impact9
Flight distance : 215886 ft
I've noticed this myself in Manual it still has something adjusting the exposure. I'm hoping DJI can turn that off in an update otherwise it's locking the AE value. Just use the [   ] icon and change it to a target. That's the EV lock.
2018-10-14
Texan
Flight distance : 1637287 ft
Impact9 Posted at 2018-10-14 06:08
I thought you can do EV lock only when shooting "Photo" but not for "Video".
2018-10-14
A CW
Flight distance : 13838848 ft
Lock the EV after setting the metering on the screen. Otherwise the exposure will change as the light changes in line with the manual settings you have made.
2018-10-14
Rocket_man
Norway
Hi everyone,
I'm experiencing the same problem with my Mavic 2 Pro. I'm in fully manual video mode (ISO 100, 4K@24 fps, aperture 5,6, shutter speed 1/50, style cloudy/sunny or whatever the conditions) but at some shots, it looks like the drone is changing the ISO or exposure automatically. It may occur when going from a very bright scene to dark (ex. during sunrise), but also at scenes with little change. As far as I have learned (I'm a beginner), the EV or M.M is just an indicator to give you information if your shot is properly exposed (too bright or too dark), and not a setting you can change. Is that correct, or am I wrong?  Any tips on this one would be highly appreciated! :-)
2019-8-17
gnirtS
Rocket_man Posted at 8-17 12:46
Hi everyone,
You are correct, in manual exposure mode the EV is simply the system showing you how over or under exposed your shot is with the current exposure settings.You 'change' it by altering the exposure.
Its easy to demonstrate - set manual, point the drone at something.  Zero the EV by adjusting exposure.  Now rotate the drone, you'll see the EV indicator change as the light levels change.
As for the other comment, remember the mavic is capable of auto iso in manual mode - for full manual you need to make sure thats off by selecting a fixed ISO.
2019-8-18
Rocket_man
Norway
gnirtS Posted at 8-18 01:52
Then I've got it right. Yes, my ISO is always set to 100 manually. I was out shooting with my drone today, and as expected - many of my clips have the same issue as described. I'll try to post some of them here now.
2019-8-18
KS-6
Flight distance : 91909 ft
I don't shoot video so I can not comment on that but I do know when using the camera in full manual ( ISO, shutter, Aperture ) I can occasionally bump either the aperture or shutter adjustments and then it will be off. That is the only way I see that issue though, user error. Otherwise it is dead on.
2019-8-18
Rocket_man
Norway
KS-6 Posted at 8-18 07:06
Ok, so you accidentally hit the aperture-wheel/button on the remote control? I'm thinking that might be the reason for me as well.
2019-8-19
Aardvark
Flight distance : 384432 ft
Rocket_man Posted at 8-19 01:14
It might well be the case that you are accidentally adjusting the aperture or shutter settings.
Have a look at the right hand wheel description on page 10/11 of the manual:-
https://dl.djicdn.com/downloads/ ... _Manual_V2.0_en.pdf
2019-8-19
Rocket_man
Norway
Aardvark Posted at 8-19 01:36
Thank you! Is it possible to "lock" these settings, so there's no chance for me to change when I'm recording?
2019-8-19
Aardvark
Rocket_man Posted at 8-19 13:23
There is no way that I'm aware of that the wheel can be disabled or functionality changed. I don't have the Mavic 2 Pro, but I think it is the same as the Mavic Pro, in that the right hand wheel cannot be changed at all.
2019-8-19
Glushakoff
Ukraine
I got the same issue!!!! Exposure is changing automatically in manual mode!!!
2019-12-12
Gelert
Flight distance : 568054 ft
Could it be White Balance ?? Have you set to AWB or selected one of the fixed options. If AWB, that can change the "light"
2019-12-12
Mirek6
Flight distance : 609724 ft
Glushakoff Posted at 12-12 04:52
Glushakoff,
We need a precise wording here. What do you mean by "exposure" is changing automatically in manual mode"?
1. When you manually lock all settings (aperture, shutter speed, ISO), you will see your picture luminescence changing when light changes. Picture will get darker or brighter depending on changing light. This means that your exposure is locked and is not changing.
2. However, if you see that your picture luminescence remains similar despite light changes, than you may say that your exposure is changing trying to compensate for light changes. This should not happen when you locked all exposure and ISO settings manually.
Which one are you observing? 1 or 2?
Mirek
2019-12-12
Glushakoff
Ukraine
Mirek6 Posted at 12-12 10:44
Glushakoff,
Mirek,
I shoot in FULL MANUAL MODE and exposure is changing itself.
2019-12-17
DRAGenDROP
Glushakoff,
number 2.
everything is manual and still the light changes, darker or lighter
2019-12-28
Labroides
Flight distance : 9991457 ft
Glushakoff Posted at 12-17 04:24
Mirek,
Are you saying that the camera's exposure settings are changing themselves (that's unlikely).
Or that the light changes as you fly around (which is quite normal).
2019-12-28
djiuser_LmvYYrr4wIYU
DRAGenDROP Posted at 2018-10-8 07:49
ok
Let it be.
When i manually darken and then Lock it.... moments later the video quickly whitens out and the Lock feature UNLOCKS.  It never stays the way i want it.   I'm surmising i must lock before flight. The attached images are relative.   The washed out image gets worse...
2020-2-17
DRAGenDROP
djiuser_LmvYYrr4wIYU Posted at 2-17 14:59
exact what I was talking about
2020-2-22
DRAGenDROP
Labroides Posted at 2019-12-28 19:07
jep, in manual
2020-2-22
12Next >
