Gimbal jump up in sport mode.
1776 10 2018-10-9
JohnnieYaz
Flight distance : 5137874 ft
I have been following subjects in sport mode with every DJI product I've owned, but for some reason my new mavic 2 pro gimbal jumps when I first push forward. See it at do this jump up at about 44 and 102 seconds. Hope its just a software fix coming soon.
Jetoberfest" (Plum Island Airport: Newbury, MA)" on YouTube
https://youtu.be/H8g-IoVBz14
2018-10-9
JohnnieYaz
Anyone else experience this?
2018-10-9
DJI Stephen
Hi there, thank you for reaching out and we're very sorry for the trouble that you have faced. May I ask how often did you receive that kind of issue? However. I would suggest to calibrate the gimbal camera and see if will work. Please keep us posted regarding it. Thanks!
2018-10-9
JohnnieYaz
Every time in sport mode pushing forward to full speed. Ill try a gimbal calibration and see if it goes away. I hate to send it in if others aren't doing this same jump.
2018-10-9
Blellow
Flight distance : 1311056 ft
What is 44 102 seconds?  In sport mode the gimbal tried it best to act like position mode, but when certain limits are reached the gimbal jumps.  That had been my experience.
2018-10-9
Blellow
Sorry for grammatical mistakes.
2018-10-9
Asainz320
Flight distance : 1061594 ft
Yes! My Mavic 2 Zoom does this as well. Its very annoying!
2018-10-9
Bekaru MP UAV
Flight distance : 15513100 ft
South Africa
my mavic pro does that too as do many others - probably all mavics (according to previous discussion we had about the subject and now also new mavics experience.) The trick i use to overcome the problem is to keep my finger on the gimbal dial - yes it does jump at first but after that with finger on the gimbal dial i maintain good control of gimbal movement. It took me a fair bit of practice to get right but it is a way around the issue.
2018-10-9
JohnnieYaz
Well this isn't good. A well ballaced gimbal shouldn't do it. My old mavic didn't do it or i just didn't notice it, if it was less noticeable  and my inspire 2 certainly doesn't shake at all. I did the calibration as recomended and will give it a try come daylight to see if it's improved some and I can ease into full speed shots. If it's still bad I would say these pro cameras may not factory counterbalanced very well or a software fix to ease into full speed may be required. Remenber the inspire 2 getting a reductionin speed just before release because it just didnt film right at that faster speed?
2018-10-9
egar1M
Flight distance : 429206 ft
JohnnieYaz Posted at 2018-10-9 21:18
Well this isn't good. A well ballaced gimbal shouldn't do it. My old mavic didn't do it or i just dodnt notice it, if it was less noticeable  and my inspire 2 certainly doesn't shake at all. I did the calibration as recomended and will give it a try come daylight to see if it's improved some and I can ease into full speed shots. If it's still bad I would say these pro cameras may not factory counterbalanced very well or a software fix to ease into full speed may be required. Remenber the inspire 2 getting a reductionin speed just before release because it just didnt film right at that faster speed?
same here! when you push full throttle the gimbal do that move!
2018-10-11
JohnnieYaz
Calibration done a did a text flight. It s does it but not every time, maybe 50%. DJI, I belive we have a issue that needs testing and a update.
2018-10-11
