Message SD Card
1690 9 2018-10-9
jcflyer23
Flight distance : 4298 ft
I am getting a message that says (SD Card is too slow for 4K video). So what is the correct cards or options? The one I have now is a SanDisk Ultra 64 GB micro XC1.
2018-10-9
Bing Err
Flight distance : 9249964 ft
DJI will say only the recommended cards are supported to work, but I've got many different cards to work just fine. Here's there list.
https://www.dji.com/mavic-air/info#0-3
Supported SD Cards
microSD
Class 10 or UHS-1 rating required
Recommended microSD Cards
16G
Sandisk Extreme
Kingston 16GB SDHC-I SDCAC/16GB
32G
Sandisk Extreme V30
Sandisk Extreme V30 A1
Sandisk Extreme V30 Pro A1
64G
Sandisk Extreme Pro V30 A1
128G
Sandisk Extreme Plus V30 A1
2018-10-9
msinger
Flight distance : 228255 ft
You can find some commonly used memory cards here.
2018-10-9
Bing Err
Here's another page I use to find the ACTUAL card speeds. A lot of SD cards are labeled 100mb/s but they are NOT.
https://havecamerawilltravel.com ... test-microsd-cards/
I have a LOT of SD cards and I've been testing the actual read/write speed on them. I have quite a few Samsung cards that test out 84-90 mb/s and they have worked just fine for my Mavic Air. I'm still testing but when I'm done I'll be posting my results to this forum. For now you can just google or follow the link above to find the tested Read/Write speed of most cards.
2018-10-9
Pequodd
Have you tried formatting the card in the Mavic? Even old Sandisk Ultra cards can sustain 12.5MB/s (100mbps) that the Mavic 2 requires. The Mavic 1 requires only 7.5MB/s (60mbps).
Class 10/U1 cards will work.
The only other possibility is the card has been used in a dashcam or surveillance system previously.
2018-10-9
jcflyer23
Well thanks guys for the great info, I just now reformatted the card so maybe tomorrow I will see if it makes a difference..
2018-10-9
Bing Err
Pequodd Posted at 2018-10-9 18:15
Great Idea. I always Reformat after every use. Also, make sure your on board memory is empty. I had choppy video once when my memory of my Mavic Air was full and there was no place to buffer the video as it wrote to my Samsung SD card. This only happened to me once so I can't confirm this is fact, just something weird I experienced.
2018-10-9
jcflyer23
Bing Err Posted at 2018-10-9 18:21
Great Idea. I always Reformat after every use. Also, make sure your on board memory is empty. I had choppy video once when my memory of my Mavic Air was full and there was no place to buffer the video as it wrote to my Samsung SD card. This only happened to me once so I can't confirm this is fact, just something weird I experience.
Yes I cleared the internal memory too.
2018-10-9
DJI Paladin
Flight distance : 318 ft
Hi there, sorry for the trouble. Check the list below for compatible SD cards for your drone. Please keep us posted if the issue is still the same after formatting your SD card. Thanks for your support.
For Mavic 2
For Mavic Air
For Mavic Pro and Mavic Pro Platinum
2018-10-10
jcflyer23
Ok guys tried to make a video and I can't get my PC to show it??? I am at a loss for what the problem is...
2018-10-11
