DJI Susan
Bradmax57 Posted at 11-7 11:34
Hi I was away on holiday for two weeks, came back and charged my mavic 2 zoom up and checked to see if any updates were available, sure enough saw the update but wouldn't update via my ipad mini and go app, kept saying failed (error 0x0000000) I then connected it to dji assistant 2 (v2.0.4) and it said it was successful, it kept saying the remote controller needs and update but the app is failing all the time so I cant update the controller, I managed to downgrade the firmware back to v1 thinking I would update it again but its just the same, after trying it says air encoder error (0x4), restart aircraft. contact dji support if it persists after restart, and then aircraft upgrading. check for upgrade completion on DJI go homepage, am I best downgrading again?
Hi Bradmax57, just to verify, has the drone been involved in the crash or hard landing before? If not, you may connect with App and check whether the firmware of aircraft and remote controller can be read. Alternatively, you may connect the aircraft or RC with DJI Assistant 2 to refresh the firmware to see whether the air encoder error is the misinformation, thank you! |
