Tomasz Kierepka
Poland
DJI Susan Posted at 2018-10-15 01:51
Hi Tomasz, thanks for heading up. Generally, the sensors icon will be red in Andriod device if the drone has not taken off. If the OA errors appear in the flight, you may upload the screen recording for further assistance, thanks! Also, please make sure the GPS signal is good enough to hover, you may test in an open filed to confirm. For the camera does not catch focus, does it only appear in pictures? Could you upload some original pictures from the SD card for double check? Thanks so much!
Lastly, the Chinese in C1/C2 has been reported to our engineers, hope they will figure it out soon. Sorry for the inconvenience caused.
Ok. I installed a new Windows 10 and downloaded Assistant 2. It turns out that under Win 10 there is still the option Restore factory settings, which I do not have in Win 7. After clicking nothing changed, the above mentioned errors except the camera - normally sharpens. After starting Mavic again, OA started working after take of and it worked properly even during the flight. During the landing, an OA error pops up. I have everything recorded, but I need a moment to share it. I noticed that after a flight of about 10 minutes, the front engines have (on the touch) a temperature of about 45C, and the rear about 30C. From what I associate, before the update they had more or less similar temperatures. I did not check anything else because I had little battery. Some messages about the controller's rods have already popped up and I have never had one. I need to delve deeper into the topic. |
