KasperGaram
Flight distance : 1049288 ft
Finland
DJI Mindy Posted at 2018-10-14 20:30
Hi Kasper, sorry for the troubles with motion lapse, is it possible to set the standby-mode in Camera Settings or whether the self-standby can be turned off?
You could use the camera's built-in time lapse, but you will need to move the Ronin-S manually, it may be not convenient.
As far as I know, it can't be turned off. There is no setting for it.
The way I solved it was I made the Ronin-S do the motion lapse and the camera use it's built in timelapse mode. Just unplug the cable between the Ronin and the Canon and there is no issue. It would just be more convenient to only use one device for it all.
Also, the Ronin-S's motion lapse "stops" the movement for every shot. As the camera and tje gimbal aren't in perfect sync, this causes a bit of a "stutter" in the time lapse (can be fixed with Warp Stabilkzer though, so not a big deal). Is there a way to make the movement of the Ronin smooth and continuous? Mahbe with the Track-mode, which then does limit me to a certain time. |
