TonyFonagerDK
Flight distance : 245013 ft
Denmark
PiVoR Posted at 2018-10-15 08:41
specs say its 21 minutes while flying at constant 25kph speed above water, i managed to squize up to 18 minutes from 100 to 0%, fun fact: at 0% drone can stil fly but you will get message that battery can be damaged so batteries have some reserve below 0% in really emergency situations.
I am aware that those battery numbers are under certain conditions.
But when I turn on my Mavic Air and its connected (it takes maybe 1 minute in total) - the batteries are close to 100%, but DJI Go say 13-14 minutes available flighttime - even before the drone has started flying.
How come it does not say 21 minutes when its turned on, and if I then start out in hard wind, flying sportsmode, it will ofcource drop to much lower flight time right away.
But this is almost when the drone has just been turned on - and battery is 100%, but flight time is much lower that the promised 21 minutes. |
