Ronin S out of control error
1325 3 2018-10-15
fansdb6ff1f7
Flight distance : 1998786 ft
Hi, I've been looking at the Ronin S to initially mount my Nikon D7200. Happy to accept that camera controls will not work as I was planning to get a Panni G5s in the future which appeared, initiallly, to be fully supported. My question to the guys who have experienced the out of control spinning is : Has this behaviour ever manifested itself when the Camera
is simply mounted and balanced and not connected to the Ronin? Thanks
2018-10-15
Wisdom Tooth
Flight distance : 1535308 ft
The issue is only present when you're tethering to the Ronin-S with the cable provided. I did a lot of shooting with my Canon on the Ronin-S before my GH5 arrived and it was perfect, but once I started tethering with my GH5 it started randomly shutting down etc.
2018-10-15
Wisdom Tooth
Wisdom Tooth Posted at 2018-10-15 05:11
So yes, you can remain untethered with your GH5 and all should be well.
2018-10-15
fans1a894973
Flight distance : 94360 ft
I cave a Canon 6D with a 17-40 mounted on a ronin s and each time i turn it on it spins out of control. I have it balanced correctly. The balance test shows excellent on all 3 axis. i have auto tuned and tried the last 3 firmware. Please advised.
2019-1-21
