Iphone 4 and Phantom Vision 2+
1524 8 2014-11-6
kw
Denmark
I loose connection with my Iphone 4. Does anyone have expirence with this issue ? Should I change to Samsung Galyxy S5 or is it a better solution ?
2014-11-6
xzgraham
S5 has a bigger and better screen also you can use coffee's app and get unlimited distance in his  Ground Station  app as well as quite a few other things.
Never had any issues with my iphone 4  which i use as a back up phone .
2014-11-6
kw
Denmark
xzgraham@btinte Posted at 2014-11-7 01:04
S5 has a bigger and better screen also you can use coffee's app and get unlimited distance in his  G ...
Thanks, I will try it
2014-11-6
philneedes
I'm having a few issues with the app crashing and also losing live feed with my iPhone4, might need to upgrade to iPhone6 maybe?
2014-11-7
kw
Denmark
philneedes@optu Posted at 2014-11-8 07:56
I'm having a few issues with the app crashing and also losing live feed with my iPhone4, might need  ...
Same for me. Now I am checking the recommanded Phone from DJI - Sa,sung S5 - I will return in a few days with the result
2014-11-8
xzgraham
HTC M8  best smart phone on the planet  at the present time .
2014-11-8
gil
Flight distance : 1379308 ft
I'm still using an iPhone 4 with one of the newer Phantom 2 Vision +'s.  I've made a couple of flights out to the 1300 foot mark before I lost video signal and that was with a lot of trees in the way.  The control signal was still good and I had no problem getting the bird back in closer where it reacquired the video.
2014-11-10
kw
Denmark
gil@wk.net Posted at 2014-11-10 23:54
I'm still using an iPhone 4 with one of the newer Phantom 2 Vision +'s.  I've made a couple of fligh ...
Thank you, but I had the problem several times. Maybee its my Iphone, but I try some others
2014-11-11
kw
Denmark
Now I checked the Samsung S5 and the problem is gone.
2014-11-18
