mavic platinum battery charged 300 times
1796 33 2018-10-18
integer
Flight distance : 113355784 ft
Greece
With this battery i have 21-23 minutes flight time. it's the battery ho came with platinum. My second battery has charged 286 times and the third has  charged 71 times.
So i believe  the dji batteries is good batteries but... I do not know if I should continue to use them after so many recharges..
what do you think?
2018-10-18
Suren
Flight distance : 13425892 ft
South Africa
That is some good charge time, I say keep using it unless you seeing some swelling
2018-10-18
integer
Greece
Suren Posted at 2018-10-18 07:25
i don't see any problem with the battery. Thanks Suren
2018-10-18
DJI Stephen
Hi there, thank you for reaching out. You can still continue to use it the only time you stop to use it when the time that there's an Error about the battery or any physical changes like a swollen battery, fly safely. Cheers!
2018-10-18
A CW
Flight distance : 13838848 ft
Impressive - here's to another 300 cycles
2018-10-18
integer
Greece
DJI Stephen Posted at 2018-10-18 08:42
thanks for the advice
2018-10-18
integer
Greece
A CW Posted at 2018-10-18 08:43
This will be a miracle!  thank you
2018-10-18
Woe
Flight distance : 4129268 ft
I say keep using it, 300 charges is impressive.
2018-10-18
integer
Greece
Woe Posted at 2018-10-18 09:34
Thanks Woe
2018-10-18
Koelkop
Flight distance : 22814806 ft
South Africa
Each of my 3 platinum batteries are now at 180 cycles, the app states they have about 3440mah capacity. I'm hoping for many more cycles before I have to buy new ones!
2018-10-18
Koelkop
South Africa
Another thing that I have noticed, many of the guys that had in flight battery failures are from batteries that had very few cycles but they were "old".
2018-10-18
Bekaru MP UAV
Flight distance : 15513100 ft
South Africa
nice going integer - as said by others already - if you getting good flight time and no physical deformaties and no error notices received - then i would feel confident to keep going with it.
2018-10-18
Woe
You're welcome.
2018-10-18
CA Mavic Pro
Flight distance : 639652 ft
Lebanon
Very impressive
2018-10-18
Bing Err
Flight distance : 9249964 ft
keep using it
2018-10-18
A CW
integer Posted at 2018-10-18 08:53
You never know
2018-10-18
FlyDK
Flight distance : 1636286 ft
Denmark
As everyone else mentions there should be no problems with the continued use of the batteries. The batteries you posess have probably been treated well. The worst enemy of the batteries is if they are discharged completely or almost and then left unused for a longer time. Also they don't like to be fully charged and unused for a long period of time and thats the reason they selfdischarge to approx fifty-sixty percent after some days.
If you make sure to charge them after use - either full or about fifty percent, they will last as long as possible. Room temp or colder storage is best.
After a five-second long press of the button on the battery, the LEDs will show its remaining life.
2018-10-19
jacksonnai
You must be flying a lot with it
2018-10-19
Alex B.
Flight distance : 21105262 ft
I suggest keep using them until they either inflate or get damaged, otherwise if they are performing as expected just keep on flying with them.
Fly safe and enjoy all
Alex
2018-10-19
Lonesome Crow
Flight distance : 406076 ft
I am assuming same bird too?  Congrats!!
2018-10-19
Sky Carrier
Flight distance : 590102 ft
Keep using it as long as there is no error or drop un flight time. Should be fine
2018-10-19
integer
Greece
Koelkop Posted at 2018-10-18 10:13
Those batteries are defective. Your batteries are still young
i wish you good flights my friend!
2018-10-20
integer
Greece
Bekaru MP UAV Posted at 2018-10-18 10:37
Thank you Bekaru
2018-10-20
integer
Greece
Yes indeed! Dji has good products finally
2018-10-20
integer
Greece
Dirty Bird Posted at 2018-10-18 22:03
Impressive.  If no errors, no sagging under load, & no swelling, they should still be good to go.
the battery works fine if you exclude reduced flight time
2018-10-20
integer
Greece
FlyDK Posted at 2018-10-19 00:15
the two batteries are in the sixth order
2018-10-20
integer
Greece
jacksonnai Posted at 2018-10-19 00:48
240 hours total flight time my friend
2018-10-20
integer
Greece
Alex B. Posted at 2018-10-19 02:01
Thank you Alex
2018-10-20
integer
Greece
Lonesome Crow Posted at 2018-10-19 07:26
yes, the same bird. thank you
2018-10-20
integer
Greece
Sky Carrier Posted at 2018-10-19 22:21
thank you
2018-10-20
jacksonnai
Malaysia
integer Posted at 2018-10-20 02:29
Wow that is a lot
2018-10-20
integer
Greece
does anyone know if we should do battery calibration?
2018-10-27
Fly74
That is great to see.... I have been hooked into drone flying after getting a free Tello... it's fun and has made me obsessed to obtain a Mavic Pro... the MP1 is already above my budget so  saving up for one in December... thinking the extra amount for the platinum may be worth it.  At any rate getting 100's of flights from a battery is really good news.
2018-10-27
$gambino$
Flight distance : 1563980 ft
Integer... I would not do a battery calibration you got this far without.... trust me I have a lot of experience with lipos rc heli 14s 12s ...6s...packs. and I have never done what DJI suggest taking the battery down that far for the calibration I understand it is for the electronic board on the battery but I still would never do that to a lipo, and I've got a lot of Cycles on my mavic Pro batteries....just like you..so I would say no I don't recommend it
2018-10-31
