#Autumn# Trucking Through Fall
915 2 2018-10-19
BaddogTwo
Flight distance : 2783189 ft
Adirondacks High Peaks: Trucking Through Fall
This was early afternoon along route 86 in the Whiteface/Lake Placid region of the Adirondacks.  The road runs along the path of the Ausable river which has many majestic cliff faces and beautiful waterfalls.
Mavic Pro V1
Control Settings:
  • EXP
  • Throttle: .25
  • Rudder: .10
  • Forward & Backwards/Left & Right: .15
  • Sensitivity
  • Attitude: 100
  • Brake: 130
  • Yaw Movement Limit: 50
Camera Settings:
ND8 Filter
Color Mode: D-Cinelike
  • Sharpness: -1
  • Contrast: -1
  • Saturation: -1
Shutter: 100
Frame Rate: 50 to 120 (Should try and keep to as close to 50, for correct motion blur)
White Balance: Sunny (Never set to auto, makes dramatic changes in lighting while capturing footage, unapealling)
Captured: 4K RAW+JPG (HDRI Off)
Gimbal Settings:
  • Gimbal Pitch Speed: 10
  • Enable Upwards Gimbal Tilt: On
  • Gimbal Pitch Smoothness: 20
  • Enable Sync Gimbal Pan: Off
Post Production/Color Grading:  Adobe Photoshop 2019/Cinelike-D_to_Rec709.cube.cub
Locations
  • Lake Pleasant in Speculator (Map)
  • Scanadaga River (Map)
  • Lake Placid/WhiteFace Mountain (Map)
  • Keene Valley/High Peaks region (Map)
  • Ausable Chasm (Map)
This post contains more resources
You need to Login Before they can download or view these resources, Don’t have an account?Register now
x
2018-10-19
A CW
Flight distance : 13877205 ft
Lovely shot
2018-10-22
jacksonnai
Malaysia
Stunning shot
2018-11-5
