DRONE-flies-YOU!
Flight distance : 1450594 ft
MagicRide Posted at 2018-10-22 07:43
This is confusing, does this mean that if you're being tracked inside a car and you drive for a mile, then initiate return home it will land where you are or land where you took off?
Dynamic Home Point is the little picture of the person as Home. When pressed, the drone will RTH to the R/C (you) instead of where it took off from as normal.
So if you’re on a boat, then launch your Mavic and enable dynamic Home Point, it’ll Return-to-Home to wherever you and the boat are now. |
