Alberto ph4pro
Hi,
I would like to ask for help, regarding problems encountered with my drone.
I have a phantom 4 pro plus, lately I proceeded to make the firmware updates, both the drone and the remote control.
For the update of the drone I used the DJI Assistant 2 software, while for the radio control I downloaded the ZIP file from the DJI site on a microSD, and I did the whole procedure indicated for the update.
The next day I went to try the drone, after having done all the calibrations I noticed some problems:
-When the device is switched on for the first time after inserting the battery, pressing the key to start a recording or the key to take a picture, the radio control works normally, signaling the video recording in progress through the typical acoustic signal and through the display. Instead, in all the other drone switch-ons if I went to give the command to start a video, nothing was reported in the radio control, same problem if I take a picture, with the difference that you hear only the first sound that goes to signal the focus while at the time of shooting you did not feel anything.
Then I looked in the gallery to check if he actually had anyway recorded videos or taken photos and the answer was yes.
Today I reloaded the updates, tested the drone and ... same exact thing, first ignition all working while all the others had the same problem.
-When I turn on the drone, it starts doing the normal automatic gimbal calibration. Once finished, almost immediately the gimbal makes a small movement that does not reassure me.
This is a problem that nevertheless occurs only at power-up and not other problems on flight or shooting.
-This anomaly I noticed before the updates, but also later, namely:
-If I move the stick to make the drone go forward, this tends more and more to move slightly to the right.
I tried to do all the calibrations, but I can not find any differences.
Among these three problems, the one that prequashes me the most is the first one.
I ask you if anyone is able to help me solve these problems and if so, how can I install the old remote control update again?
I thank
P.S. sorry if there are errors in writing
