Ben Mason
Flight distance : 610614 ft
I would recommend sending the drone to DJI, although they may charge you for simply calibrating the gimbal, you lose nothing by asking though.
Not that i would recommend this but you can calibrate the Mavic Air gimbal using the spark software, then calibrate the gimbal in the DJI GO 4 app. I've seen this work but if i was you i would send it to DJI.
Also for future reference it is possible to take apart the gimbal and keep the camera+camera sensor, so you only replace the gimbal, you would still need to calibrate it, but you can avoid Camera sensor data errors that also require the software to resolve. |
