Todd Harper
Flight distance : 180669 ft
Filters are a necessity when it comes to cameras. They have to fit and proform you you expect them to.
I tested the newest versions of both the standard and polorized. The pack consists of the following: ND4, ND4/CPL, ND8, ND8/CPL, ND16, ND16/CPL
Each filter fit and worked as it should. They fit tightly against the body of the camera and thanks to the machined grips on each side, they can be removed with just a little effort.
Dialing in the filter on the polorized versions was not a problem. The filter itself provides just enough resistance, letting you know that it once you set it, it will not change while in flight.
Overall they are great addtion and their color matches well against that of the M2P.
F-Stop Filter Pack
