New Phantom 4 Pro V2.0 Firmware Released (11/23/2023)
12
13719 53 2018-10-23
fans6adfe12c
Akin_rw Posted at 2018-11-24 12:02
Latest Update:
After checking out my Windows Event Logs, I noticed that there was an MS ID 1002 event each time the DJI Assistant Update failed around 66%.
Any update or fix for this? I am experiencing the same problem trying to refresh the firmware through dji assistant 2 for phantom.
I updated the firmware initially via the controller and ipad.  After which my gimbal stopped working ( moved during startup then would move sporadically during flight. Now after resetting to factory default settings its limp after startup) I figured refreshing the firmware might help but it fails at the same 66% mark with the same error code
2019-6-26
djiuser_BOM3S92T24ky
Latest Update:
Did you ever get a resolution for this?
I am in the same boat - unresponsive gimbal after flying a while, can't upgrade to v01.00.5200 nor can I downgrade successfully. Upgrade fails at 72% after reboot of the drone. I am seeing the same DHCP issues from the NDIS Network device.
2022-7-1
UAViator53
Flight distance : 692090 ft
Just updated the P4P firmware and I get an Aeroscope menu?
2023-11-25
Txww
Flight distance : 5235886 ft
After the update, where can I find the remote ID serial number at?
2023-11-27
bmid
Is remote id on phantom 4 performed via wifi broadcast? Drone Scanner on iOS can only see bluetooth 4 messages--is that why I can't see it transmitting?
There should be a menu to configure remote id, since people need to be able to set their license, at least in the EU. Where is the menu?
2023-11-28
LaurenOE
Flight distance : 969452 ft
I've been flying Phantoms for years and now, with this new update they've taken away the "Pull Back" to go up, and "Push forward" to go down. Why DJI? Why did you do this? They've messed up the custom stick just like on the Mini 4 Pro. FIX THIS!!!!!!
2023-12-1
fans654e9e89
Flight distance : 1640367 ft
Poland
Will the GS Pro app be updated to work with the latest Phantom 4 Pro v2.0 firmware?
2023-12-2
DJI Tony
fans654e9e89 Posted at 12-2 07:07
Hi there. After the V2.0.17 version was released, the iPad GS Pro entered its product maintenance phase, and there will be no new features to be launched in the future, nor will it be adapted to new aircraft models or iPads, but the existing functions will remain normal. Thank you for understanding.
2023-12-20
fans654e9e89
Poland
DJI Tony Posted at 12-20 02:43
Do you plan to remove this inconvenience? -  "DO NOT update to this firmware version if the GS Pro app is being used with the aircraft. Otherwise, the aircraft cannot be used."
2023-12-20
DJI Tony
fans654e9e89 Posted at 12-20 11:21
Hi. We cannot provide information yet about any upcoming firmware update but I will forward this to the related team for awareness. We appreciate your patience.
2023-12-23
BaddogTwo
Flight distance : 2783189 ft
Where do I locate the Remote ID serial number for Phantom 4 Pro V2 and a Mavic 2 Pro after updating firmware and the DJI Go 4 App?
2023-12-26
Mr. Strat
Flight distance : 4542854 ft
BaddogTwo Posted at 12-26 07:10
Three dots in upper right corner
Scroll down to About
You need to have a GPS signal (meaning outside) to see it.
2023-12-26
bmid
The FAA approved this firmware's remote id feature a few days after the release:
https://uasdoc.faa.gov/listDocs/RID000000759
2023-12-27
StaGia
Flight distance : 3038 ft
Greece
Connection Problem
Samsung Galaxy S22 ultra - P4Pv2
I am totally unable to connect my P4P v2 (latest firmware) at DJI GO 4 App (v4.3.60) running on my Samsung Galaxy S22 Ultra (EU / Android 14).
Had everything updated - tried everything I can think.
Never had this problem on Samsung S9+ and S20+ (EU models with older android versions).
I've read topics regarding same issues.. At the end of the day, is there a solution..?
Not sure if it is the Exynos chip, the Android 14 or something else, BUT I expect DJI to solve this issue.
After all, DJI is considered to be one of the most prestigious drone manufacturers.
Finally, yes I have kept my S20+ but it doesn't have it's own a SIM card wich makes it almost impossible to get GPS signal.
As you understand, buying an extra connection (SIM card), just to operate my P4Pv2 in a 4 years old mobile, is not a logical solution.
2023-12-27
12
