Help needed. Why has my map display stopped showing?
599 8 2018-10-24
djiuser_6skJaeLno6Ca
Flight distance : 21316 ft
Hope someone can advise on the map no longer showing up in the display?, all I get is a black empty box.It was working fine last week and now no longer displays. It's annoying and I lose confidence, especially with checking home point etc. My area has been downloaded for offline maps and the file is shown as downloaded, anyone solved this issue? Thanks in advance.
2018-10-24
DJI Paladin
Super Moderator
Flight distance : 318 ft
Hi there, our apologies for the inconvenience. May I know what mobile device, ios/android version and DJI Go 4 app version you are using? If it is convenient for you, kindly provide a screenshot showing the issue so that I can check it on my end. Please back up your files and sync your flight records and then reinstall the APP. After that, please cache the map when your mobile device has internet access to update the location. I would recommend you do it before flight. Thanks for your support.
2018-10-24
Thanks for getting back to me. I am using an S7 edge, latest Go4 app version installed, and android version 8.0 I have synced flight records but not able to screen shot. At home with WiFi on the map shows up but seems intermittent when in flight mode. Will reinstall like you have advised. I recall seeing others have had this as well. Will update when able to test again.
2018-10-24
DJI Paladin
Super Moderator
djiuser_6skJaeLno6Ca Posted at 2018-10-24 05:11
You're welcome. For Android devices, to cache a map, enter the map screen, zoom in the map as required, drag the map to the position you want to view and wait until it is displayed clearly. Then the map can be viewed though Internet network is unavailable. This method also applies to iOS devices. Or turn on Cache Map in the Background under General Settings in the app, as shown in the figure below. I will wait for your update, thanks!
2018-10-24
msinger
Flight distance : 183694 ft
Try the fix mentioned in this post:
https://forum.dji.com/forum.php? ... =170324&pid=1620193
2018-10-24
Hi, thanks will try that advice you have pointed to. Have reinstalled the app. Will test and get back to you. Regards.
2018-10-24
Hi, I think it's all working now, the map shows up when offline and will follow the tip in the linked post above. PS the spark menu does not show the option to cache the map in the background? Anyway will hope this works thanks for help.
2018-10-24
djiuser_4sLt1qLPkkvB
Flight distance : 53022 ft
DJI Paladin Posted at 2018-10-24 05:23
Isn't this the method for Mavic? The DJI Go app with Spark doesn't have a map option in the settings (nor HD)
2018-10-24
Donjuan.
Flight distance : 1433858 ft
thats kind of like how my crash started. it was all perfect till last month then alot of crazy things been happening to sparks.hope they figure it out so no one has this serious problem that have ppl losing theyr drones...good luck bud
2018-10-24
