New firmware 0500
1611 15 2018-10-24
HenryHM
Flight distance : 795404 ft
Hi guys,
I have just upgraded my MA using the DJI Go 4 and did not reset anything, I had no issue with it being stable in a windy situation as you can see in the video below.
I think all the issues of drifting and stability are hardware related so if the propellers are in good condition I would suggest to get the drone repaired/Checked by DJI..
What do you think?
2018-10-24
DJI Natalia
Hello there, thanks for reaching DJI. However, it seems like we cannot watch the video that you provided. Could you please try to upload the sample video via google-drive or Dropbox and provide the link here so we can check. Thank you.
2018-10-24
hallmark007
Flight distance : 9827923 ft
Your video is set to private.
2018-10-24
小仙女的星巴克
Flight distance : 4657841 ft
Oh no.....I can't watch it
2018-10-24
DJ-MA
Flight distance : 127713 ft
Video works well if you click the link. It does seem hold well in 36 km winds at 120 m altitude.
2018-10-24
WayneMHK
Flight distance : 694728 ft
"I think all the issues of drifting and stability are hardware related so if the propellers are in good condition I would suggest to get the drone repaired/Checked by DJI..
What do you think?"
I think that if that were the case, a perfectly performing aircraft wouldn't suddenly get a mind of its own after an upgrade.  What do you think?
2018-10-24
Flycaster
Make sure you check ALL of your settings. some may have been reset to default at the time of an update installation.
You know, like , upon Signal loss, RTH, Hover, or Land....Return to home height etc, etc, etc....
2018-10-24
Vofas
Flight distance : 200853 ft
Russia
What obstacles do the rear sensors signal on 23-25 seconds of video?
2018-10-24
HenryHM
Vofas Posted at 2018-10-24 22:11
nothing really.. interesting right.. it honestly happens every now and then
2018-10-25
HenryHM
Flycaster Posted at 2018-10-24 10:40
will do Cheers
2018-10-25
HenryHM
WayneMHK Posted at 2018-10-24 09:21
What do you think?"
Yes in that case i agree most people though i read were about the issue being since 0400 and users expecting a resolution by now.
2018-10-25
HenryHM
Just click watch on Vimeo
2018-10-25
HenryHM
hallmark007 Posted at 2018-10-24 08:52
2018-10-25
HenryHM
DJI Natalia Posted at 2018-10-24 08:42
2018-10-25
HenryHM
should be good now..
2018-10-25
hallmark007
HenryHM Posted at 2018-10-25 03:15
Yes thank you I watched it, and it looks pretty stable, it is hard to know what is causing the problem for some, it’s also hard because for some it sounds like it’s causing them not to be able to fly, I’m not sure if reporting is somewhat being exaggerated as very few have sent in their drones for repair. I believe some proper calibration and general flight envoirment may help others with this problem.
2018-10-25
