RONIN 2 - major issue - motors not responding - help asap!
1539 3 2018-10-24
Justin Lovell
Issue:
1. Ronin 2 motors will not respond.
2. Happened soon after 'binding' the remote to the ronin 2.
3. Have tried to upgrade and downgrade the firmware multiple times on multiple pc/mac systems and using multiple cables.  It fails every time. Getting multiple errors - constantly "the pitch device is not connected!"
4. Tried reseating the batteries, swapping batteries, reseating the sled, running using the battery power cable to the sled.
See attached link for photos of some of the errors.
https://photos.app.goo.gl/dEMB9S23xrmpNFMb8
Sent this to tech support:
Subject: Motors not responding
Message: Hey Guys, Major problem on set. We had to pull out our Ronin 1 to replace the Ronin 2 and now in big trouble with production. We setup the r2, attempted to bind the remote, and then the motors all went limp. Binding failed and now the ronin is dead and not responding. We also clicked on the "Logs" option. That's all that we've done and now it is not responding. Tried to refresh the firmware on the r2 (1.03) but i get the error "0401 pitch device not connected". If i go into the monitor menu I have errors on Aircraft, remote controller, d.bus receiver but green on power hub. Any idea what we can do? Attempting to roll back to a previous firmware. Thank you!
2018-10-24
DJI Susan
Hi Justin, we're sorry to read the troubles. Is there any chance change to another PC and refresh the firmware again? If the issue persists, I'm afraid that you may consider sending the unit in for diagnosis: https://www.dji.com/support The designated team will offer you a proper solution according to the damage assessment.
2018-10-25
Justin Lovell
Tried that.  Sending it back.
Thanks Susan
2018-10-28
djiuser_ek52CmzP11vo
Flight distance : 82690 ft
Morocco
Hello,
I experience the same issue with my Ronin 2, the motors would not respond, I have tried to refresh the firmeware on multiple PC but to no success, I did the calibration and it was completed I also tried to restore to default options, could you please help me finding a solution ?
2023-5-3
