N3 Stops Recognizing SBUS Input
402 15 2018-10-24
davidbitton
I'm running an N3 -- with up to date formware -- along with a Dragonlink Nano RX -- also up to date -- using SBUS output. On more than one occasion, the N3 stops recognizing the SBUS input from the receiver. If I select LB2, confirm the change, then switch back to SBUS, confirm the change again, the N3 is back to recognizing SBUS input. Is there something special about the sbus "flavor" that N3 expects? My next step is to try a FrSky receiver and see how that goes. Has anyone else experienced this? Thanks.
2018-10-24
Flight distance : 2
Hi David, sorry for the troubles with SBUS port, the issue will be forwarded to our engineer for analysis, we will keep you updated once we hear anything from them, thanks for your patience.
Please let us know if the issue persists with FrSky receiver, thank you.
2018-10-30
davidbitton
DJI Mindy Posted at 2018-10-30 02:34
Mindy,
  Just to let you know, I tried two different FrSky XSR receivers and neither one was recognized by the N3 at all. So far, only the Dragonlink Nano RX was worked at all.
2018-10-30
Flight distance : 2
davidbitton Posted at 2018-10-30 04:11
Mindy,
Alright, we have forwarded your issue to our engineers for further assistance and will keep you updated, please wait patiently, thank you.
2018-10-31
davidbitton
DJI Mindy Posted at 10-31 02:52
Where are we w/ this? Right now I have an unusable N3. Thanks.
2018-11-5
Flight distance : 2
davidbitton Posted at 11-5 05:36
Our engineers are still working on locating the problem, there is no update at the moment, I will come back to you once I hear anything from them, appreciate your patience.
2018-11-6
dynamo_au
at the moment i have a expensive paper weight
mine wont recognise the sbus at all  it just flashes yellow  software does not see transmiter even on the sbus setting it just flashes i sent it back to dji when it came back no change different receiver same thing recievers check out all good in other system i am at a loss
2018-11-21
Multirotor77
Malta
davidbitton Posted at 10-30 04:11
Mindy,
David, Mindy,
I have an N3 connected via SBUS with an FrSky X8R receiver for a Taranis x9D plus radio. I am experiencing exactly the same phenomenon as David is seeing on the Dragonlink (SBUS is lost, switch to LB2, switch back to SBUS and its fine, switch off everything, switch on again and SBUS is lost again). Would really like to know how to solve it. Cheers.
2018-12-5
davidbitton
DJI Mindy Posted at 11-6 03:53
This can't keep going on. When shall we expect a fix; or a refund?
2018-12-5
Flight distance : 2
davidbitton Posted at 12-5 14:35
Hi David, sorry to have kept you waiting, just got the feedback from our engineers, we have been aware of this, it is recommended to downgrade the N3 firmware to v1.7.1.5 at the moment, this issue will be fixed in the next firmware version, sorry for the inconvenience caused and thanks for your patience.
2018-12-6
Flight distance : 2
Multirotor77 Posted at 12-5 13:55
David, Mindy,
Hi Multirotor77, sorry to know you have the same issue, please check my post in 10#, thank you.
2018-12-6
Flight distance : 2
dynamo_au Posted at 11-21 16:47
Hi dynamo_au, please check my post in 10#, we sincerely apologize for the trouble caused.
2018-12-6
Multirotor77
Malta
DJI Mindy Posted at 12-6 20:00
Hi Mindy, Thanks alot for your support, would please provide us with guidance on how to downgrade or N3s to the version of firmware you have indicated. Cheers.
2018-12-8
Flight distance : 2
Multirotor77 Posted at 12-8 01:30
Please connect to DJI Assistant 2 and select the lower firmware version to downgrade.
2018-12-8
WiSi-Testpilot
Exact the same problem with A3 and version 1.7.6.0.
1.7.5.0 works.
Best regards,
Wilhelm
1-7 11:29
Passagyrs
Hello, I been back and forth with email support on this same exact issue using a Futaba T10J/R3008SB and Hobbywing X-Rotor Pro 40A Esc's.  After 2 weeks of SLOW response I haven't even gotten as far as I have reading this one thread.  Everytime I cycled the power I lost the SBUS connection, BUT only if I did any channel assignment changes.  I also could not test the motors, start the motors or fly the simulator.   I found this thread and now have downgraded two generations back on the firmware and I can now keep my radio setting, test the motors BUT I cannot fly the simulator OR worse I cannot figure a way to start the motors.  I would take any help I can get....becoming very frustrated with my upgrade from NAZA-V2....
1-8 04:48
