SLOW SD CARD AND VIDEO NOT RECORDED
1060 5 2018-10-25
AlexPapadas
Flight distance : 93235 ft
Greece
Hello ,
From my last flights i checked that when i shoot video or intelligent flight mode , the  footage is not available thru the app. I can only see this footage on my pc when i connect the MA. Did anyone else face the same problem? Also with  a class 10 sandisc micro sd the MA says that the card is slow for video recording.
2018-10-25
Tomcatuk
Flight distance : 28743 ft
Sweden
Not 100% sure but what about "Cache during Video shooting" switch in the app.
More on this https://forum.dji.com/thread-88288-1-1.html
https://www.dji.com/mavic-air/info#faq
SD Card Capacity        Class/UHS
16 GB        Sandisk Extreme;
Kingston SDHC-I SDCAC/16GB
32 GB        Sandisk Extreme V30;
Sandisk Extreme V30 A1;
Sandisk Extreme V30 Pro A1
64 GB        Sandisk Extreme V30 A1;
Sandisk Extreme Pro V30 A1
128 GB        Sandisk Extreme V30 A1;Sandisk Extreme Plus V30 A1
2018-10-25
DJI Gamora
Hi Alex, thanks for reaching DJI Forum. We do appreciate bringing this query to us. We do apologize for the troubles you had recently with your device. May I ask for the screenshot of the SD card you are currently using? Have you formatted the SD card when you activated the aircraft? I will be providing some list of recommended SD cards below for your reference. Also, I would like to ask if the aircraft's firmware is at its latest version which is the V01.00.0500, remote V01.00.0200. I would be providing also the list of supported devices below for your reference. Should you have any concerns, don't hesitate to reach us. We're here to help you. Thank you.
2018-10-25
msinger
Flight distance : 228255 ft
@AlexPapadas, which SanDisk memory card are you using?
2018-10-25
FantomAerial
Flight distance : 299 ft
I got the same message when using the Sandisk Ultra 128GB Micro SDXC UHS-I Card with Adapter -  100MB/s U1 A1 - SDSQUAR-128G-GN6MA.  It is a class 10 card.
2018-10-25
AlexPapadas
Greece
msinger Posted at 2018-10-25 04:00
I use an ultra sandisc 32gb u1 a10
2018-10-26
