Bashy
Flight distance : 2354357 ft
swoosh0829 Posted at 2018-10-26 22:29
Hi bashy , no I haven't tried that I only wear my coat . Good point on the windproof but being that it allows sweat vapor through. Wouldn't it allow the hot air of the phantom to escape? The only waterproof membrane I see so far is the phantom-rain wetsuit. From what I have read so far there suit is only to make it rain resistant not waterproof. The main thing im trying to cure is drone falling into body of water and the ability to recover it and fly. Appreciate the Input
Thats why i said it, give it a try ;) unless the membrane in damaged, you cannot blow through it, hence windproof, it will not work as a breathable material in the sense that you want it, many years ago, a shop up in Scarborough (UK) where i used to live had a bowl with gore-tex membrane over it with water on top of the membrane, never leaked, even back then (mid 90's) . If i remember right, sweat is a vapour thus having much, much smaller molecules, gtx is a ptfe based material, you wont blow through it. |
