KingCore
Hi Banan1970, thanks a million. Did what you've shown in the video and whaddaya know, the battery works again and the drone can take off!
For everyone else that's reading, Banan1970 has mentioned it perfectly, but because I was searching a bit: the lock closure sensors as stated above are below the spring on the inside. Once you've opened it, you can see that the two wires are attached here and come from the battery. If you look on the inside and move the lock (the bar on the outside which you place and remove the battery from the drone), you can see when the bar moves there's a sensor that becomes pressed in (giving a signal to the drone that it can take off). One of these sides was alright with me, the other not. After jiggling it a bit (pressing on it from the outside and on top of the depressed sensor) it came out, and now it is working fine again.
@DJI: Just a tip: I've seen this message a lot of times across many forums, so would be great if a new version of batteries would not have this mechanism. |
