PhilippN
Czechia
Hello,
after I turn my (perfectly balanced) Ronin M on, the tilt axis gets balanced well at first, but then it slowly aims downwards by a few degrees. Then its stuck to this wrong level. When I turn SmoothTrack Tilt axis off and restart, the problem disappears. But as soon as I turn the smoothtrack function (for tilt axis) back on, it always drives the tilt motor down after a sec and it never aims forward then.
Also the pan axis in default settings aims a little to left.
Firmware update did not help, neither did default settings reset or recallibration on horizontal leveled surface.
Any help? Is it an error and a reason to return the ronin to my vendor?
Thanks.
