Enhanced Warning Zone Pop-up Every 2 Seconds
566 13 2018-10-28
Bluehook
Flight distance : 790814 ft
Today, in my second flight after 0500 update, flying in my usual spot (where this never happeneed before) I kept getting the pop-up screen;
Your aircraft has entered an enhanced warning zone.
(Recreational airport). Please fly with caution.
I agree to bear full responsibility for my flight in this zone.
(tick box and click/accept)
By unlocking you reaffirm all terms and conditions of use.
2 seconds later, it pops up again -- this never stops.  This presented a serious safety issue, blocking my view of the camera feed and disallowing me certain functions like the ability to switch over to map view.
I'm assuming that this is a glitch as it has never happened before the update.  I've researched it online but did not come up with a conclusive fix to my situation.  FYI, I use a decommisioned android phone with no cell service as my attached device.
Help.
2018-10-28
QuadFunAus
Flight distance : 38832 ft
I have not had this happen, so I can't say from experience, but maybe you need phone reception for the acceptance of responsibility to go through to DJI!  Can you try on a phone that has a data plan?
2018-10-28
Mullheliflier
Flight distance : 3949026 ft
I have had this message appear fairly regularly and persistently. It seems to just stop on its own. My flying buddy was getting the same frequent message. It appears to be a bug.
2018-10-28
Jos A
That's the reason why people are delete the NFZ and use a modded app.
2018-10-29
Bluehook
Any chance I could get a moderator/someone with "DJI" in front of their screen name, to help with a fix?
I'd like to fly today but can't because this issue makes it unsafe.
2018-10-29
Drone to be Alive
It also happened to me when I was in Porto flying at Luis I bridge, same warning pop-up. I tried reaffirming the terms and it won't turn off so I continue d to fly until the warning went away.
2018-10-29
Bluehook
Drone to be Alive Posted at 2018-10-29 11:47
At least yours went away.
Mine doesn't.
2018-10-29
Bluehook
WTF DJI?
Still no help?
Right now, this thing is useless, I have an $800 dollar paper-weight.
How do I start the return process?
2018-10-29
DJI Tony
Super Moderator
Hi, my deepest apologies for the inconvenience that it caused and the late response. I would like to clarify that you've been encountering this issue upon updating the firmware, correct? May we have the model of your device? Did you try to use a different device for us to isolate the issue? You can check as well on our geo zone map if the location would be restricted using the link below. Please keep us posted for further assistance.
www.dji.com/flysafe
2018-11-5
Bluehook
DJI Tony Posted at 11-5 12:10
www.dji.com/flysafe
Thank you for your response.  I flew in a different location yesterday and got no warnings  -- oddly, I was inside a warning zone.
So, to summarize;
Inside warning zone - no pop-up warnings.
Outside warning zone - continuous pop-up warnings.
2018-11-5
DJI Tony
Super Moderator
Bluehook Posted at 11-5 18:15
So, to summarize;
Hi, thanks for the updates. It'seems that this issue is unusual, did you try to use a different device or delete and reinstall the app? Please take note that you have to save the files and the flight records should be synced before deleting the app. Kindly keep us posted if the issue would persist. Thank you for the support.
2018-11-6
Flycaster
Go back one rev in the firmware before you had issues.
2018-11-6
Bluehook
DJI Tony Posted at 11-6 09:14
Will do, thank you again.
2018-11-6
DJI Tony
Super Moderator
Bluehook Posted at 11-6 10:35
If the this won't work, you can consider restoring factory defaults and refresh the firmware of your aircraft using the DJI Assistant 2 to see if there will be changes as well, as you've mentioned that it happens upon updating the firmware. You can download the link using below. Thank you for the support. Kindly keep us posted on the latest progress.
https://www.dji.com/mavic-air/info#downloads
2018-11-6
