KlooGee
Flight distance : 10322047 ft
So far I can't get it to work with any of my controllers. Spark, two Mavic Airs or two Mavic 2.
Their FAQ is confusing on what is actually supported. They have a different list in FAQ item #5 and #6.
It looks like the Mavic Air should be supported as it is in both lists, however, I'm stuck with the problem that the current drivers don't work with the Mavic Air RC. If you download DJI Assistant 2 from the Mavic Air site, you get v1.2.4. There are a million threads about the RC not working with this version and that you have to go back to an older version. Unfortunately, DJI has removed all access to older versions of DJI Assistant 2.
So currently, neither DJI Assistant 2 nor DJI Simulator recognize my Mavic Air's RC. When I connect it and turn it on, it just goes into a perpetual loop in Win10 of trying to connect and load the driver and then disconnecting it.
I've been on with DJI's Online Chat for about an hour now trying to figure out a solution. |
