TBoyAZ
Flight distance : 31345 ft
Are you using the Goggle RE or the regular Goggles?
Are you also running the latest firmware for Everything?
You running the 5.8ghz for the Craft of Goggles?
Using pagoda antenna or not?
Sorry didn't meant to flood you with a ton of questions there, just curious if there is something setting wise that you have setup that may be different from what we are all doing.
I had some issues with mine when I first got them in, I purchased the M2P with Goggles RE, but I recently discovered that I didn't have the latest firmware on the goggles RE so just updated them and will give it another test. However, I will have to head out somewhere that doesn't have all the WiFi pollution that I have out here.
UPDATE 05/27/2019
- I Made sure all my firmwares were upto date
- Screwed in the 5ghz antenna
- powered everything up
- I was able to fly over a 1000ft away, i went about a mile without issues.
I do know where i live is heavily congested with signals galour.
When i tested it, i went out to a mountain range and just fired everything up it worked fine for me. (Still is working fine too, Knock on wood)
I noticed that it was mentioned when a person purchased and used the smart controller that all of their issues went away. I too have purchased the smart controller (A while back) and now am just waiting for it to come it. However, as of right now i am no longer having the issue once i refreshed all the firmware and started using the 5ghz antenna with the goggles RE.
Wanted to post my update in hopes that this may be helpful.
Thanks
