larryc43230
Flight distance : 664534 ft
DJI Susan Posted at 11-2 00:33
Hi Larry, thanks for keeping us updated. Just to verify, the RC has been powered on and the software has been launched, right? Does the issue remain if connect with DJI Assistant 2? Alternatively, you may refer to the below operation to confirm: Turn off the Simulator and RC, re-plug the USB cable, turn on the RC, then turn on the Simulator to see whether it works. Please keep us updated on the latest progress, thank you!
When trying to use the simulator software, the RC was powered on and the software had been launched. The problem occurred when I connected the RC to the computer with a USB cable. That was when Windows played the "Connect" chime, then the "Disconnect" chime, and then repeated that sequence until I unplugged the USB cable.
I've already tried connecting the RC to the computer without any software running (the simulator or DJI Assistant 2). Windows plays the same sequence of chimes, Connect/Disconnect/Connect/Disconnect, until I unplug the USB cable.
I launched Device Manager, and saw that a component appeared and disappeared in sync with the chimes, under "Other devices". The component was named "CDC ACM Data".
I right-clicked on the device (when it appeared) and selected Properties.
After I heard the Connect chime, the status read "The drivers for this device are not installed (Code 28)."
After I heard the Disconnect chime, the status changed to "Currently, the hardware device is not connected to the computer (Code 45)."
This repeated every couple of seconds until I disconnected the USB cable.
The exact same thing happens when DJI Assistant 2 is running. DJI Assistant 2 never "sees" the RC connected, and the Connect/Disconnect chimes keep playing.
It's obvious (to me, anyway), that the necessary USB drivers were never installed, either when I earlier installed DJI Assistant 2 or more recently when I installed the simulator.
Where can I find and install the USB drivers?
Larry |
