DJI Flight Simulator installation confusion
12
29935 54 2018-11-1
getinthewild
I had the exact same problem when installing the software.  Obviously, there is a problem with the installation software.  DJI - Why don't you solve the obvious problem so we don't have to all go through this headache of getting a simple software solution up and running?  There's obviously a problem with the forced upgrade to version 2.1.0.1.
2018-11-15
djiuser_kdwWiFRSXKVC
Klaus W. Posted at 11-2 01:56
One note of caution: Make sure your computer meets the stiff system requirements (64bit, 16GB RAM, 6GB VRAM, SSD + 80 GB to spare) before installing...
Why on Earth would DJI sign off on a flight simulator for training  - very useful to beginning pilots - that would have pc requirements that are higher than for almost every game and higher than that of most pcs for even video editing - if that is in fact true, thats one of the dumbest failures Ive ever heard
2018-12-7
fansb21184da
Flight distance : 48330 ft
Alguien con este error?? Help Please
2019-3-7
cutis
Flight distance : 1695351 ft
djiuser_kdwWiFRSXKVC Posted at 2018-12-7 22:01
No. Statusquo is left in dust.
Consider, their lead.
Consider your involve.
Then consider your expect.
2019-3-31
cutis
Xps13 good 1413usd
2019-3-31
djiuser_RAMvUClQpgWn
South Africa
Does this software really work? I've never struggled like this just to get software installed.
2019-4-3
South Africa
2019-4-3
MOSAB
Palestine
the application it show my in input email "invalid email address"
2019-6-30
EdmundoXavier
Brazil
djiuser_Yyqguru7gs8X Posted at 2018-11-2 23:16
hello, I installed the software but when I go to open it gives me the following error message:
NetworkError Error 008_008 (000_0263) what is it?
Thanks if you want to help me
Install the UE4PrereqSetup_x64.exe file that is in the C: \ Program Files (x86) \ DJI Flight Simulator folder.
2019-12-4
Gabriel.83
Flight distance : 11086 ft
Dear all,
I have a problem with this simulator.
Everytime that I try to open it, appears a message: error file 005_000 {000/0114}
Can anyone help to fix it?
2020-1-24
Hover-Fly
Flight distance : 2425 ft
The installation experience is not good at all. It lacks any form of professionalism on the UX/UI. To then try and sell the full package at 2500 USD or 130 USD per month is ambitious. If you are lucky enough to get it working it is excellent (and it is luck , trawling through and reading the right threads on the forum), however since the first thing people see is the installation process, I bet DJI don't sell too many full packages. Cheers and regards.
2020-1-24
jdeuxm73
larryc43230 Posted at 2018-11-1 07:51
Yes, this PC is running a 64-bit version of Windows. I wouldn't have begun this process otherwise, I knew of the software requirements.
On maybe the fourth attempt to get the software up and running, I tried changing that "Installation Location" to the correct directory on my C:\ drive. At that point, several GB of additional stuff was downloaded, and I was eventually presented with a window that had a "Run" button. That started the simulator software, and after a bit of fiddling and guessing I was able to select Mavic Air as the drone to be flown.
Bonjour,
Si vous avez installé Windows 10 à partir de Windows 7 ou 8, les anciens pilotes de windows 7 (ou 8) ne sont pas effacés et entrent en conflit avec Windows 10.
Il faut une installation vierge de Windows 10, et pas une mise à jour ou une migration de 7 ou 8 vers 10.
Les pilotes de Windows 10 sont parfaitement compatibles avec dji flight simulator.
Cordialement
2020-4-13
djiuser_mopyXI9hxOPZ
DJI Stephen Posted at 2018-11-1 07:33
Hello larryc43230. I am sorry to know that you are having issues installing the DJI Flight Simulator. I understand that you are using a Microsoft Windows 10 computer. Please make sure that your system is running on a 64 bit rate. Because, as of the moment the DJI Flight Simulator runs on a 64 bit rate platform.
I am having the same problems with DJI Flight simulator.  It keeps giving me an error message no matter what I do.  I do have a Windows 10 64 bit computer.  Please tell me I am not going to have to buy an Ipad to run the simulator for my drone......
2021-4-6
djiuser_T6LCTATyj9hR
Flight distance : 20781 ft
Hello all.
   I purchased a high end gaming computer that exceeds all the specs for download, including RAM, graphics card and HD space, as well as 64 bit windows 10. I downloaded the free version of the DJI Simulator and had to manually open one of the files to remove an 0808? error I was having at startup, but it was quickly resolved and the free version ran perfectly.
After a month of playing with it I purchased and downloaded the Enterprise Version and noticed I was suddenly having slow loading times. I deleted the software and downloaded it again, but I still have the same issue.
Can anyone tell me what I can do to make the load time go down to what it was. Its currently about 90 seconds to 2 minutes to load. After it loads, I feel it works just fine, its just that slow load time that is my issue.
Thank you for any help you can offer.
2022-1-30
fans641e6356
Does this simulator work with the Mavic Pro? I too, have had issues getting this program to work.
2022-3-9
12
