jdeuxm73
larryc43230 Posted at 2018-11-1 07:51
Yes, this PC is running a 64-bit version of Windows. I wouldn't have begun this process otherwise, I knew of the software requirements.
On maybe the fourth attempt to get the software up and running, I tried changing that "Installation Location" to the correct directory on my C:\ drive. At that point, several GB of additional stuff was downloaded, and I was eventually presented with a window that had a "Run" button. That started the simulator software, and after a bit of fiddling and guessing I was able to select Mavic Air as the drone to be flown.
Bonjour,
Si vous avez installé Windows 10 à partir de Windows 7 ou 8, les anciens pilotes de windows 7 (ou 8) ne sont pas effacés et entrent en conflit avec Windows 10.
Il faut une installation vierge de Windows 10, et pas une mise à jour ou une migration de 7 ou 8 vers 10.
Les pilotes de Windows 10 sont parfaitement compatibles avec dji flight simulator.
Cordialement |
